Old 10-23-2017, 02:21 PM   #55
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
Thanks man. I went both feet in on the clutch and brake pedal right when I started to spin.
I have a hard time looking at the data on my phone. Shoot, I'm still trying to figure out this software lol. Might be better to export the data and look at it on the PC using another software.
If you lack driver skill, add horsepower.
deng is offline   Reply With Quote
Old 10-26-2017, 01:30 PM   #56
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Originally Posted by Jason@SportsCar View Post
Sideways across the track, then into the dirt, you are lucky that did not roll. :(
Did you have data to pull your mph and lap times?
B Spec record is a 1:44.3, considering you are on street tires (I assume you still are) you were clicking off pretty good times.
This.
Deng is certainly a good driver with a well setup car, he is on RE71R tires.
ArmstrongRacing is offline   Reply With Quote
Old 10-26-2017, 02:04 PM   #57
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
I totally overlooked this part of your post. Thanks! and I am still running on street tires.
Originally Posted by ArmstrongRacing View Post
This.
Thanks man, I still need a lot of seat time though
and I'm running 205/50 Dunlop Direzza Star Spec IIs at the moment.
Thanks again guys, it means a lot coming from the both of you.
Old 10-26-2017, 03:06 PM   #58
ArmstrongRacing
Data doesn't lie
oh.....oops lol
Old 10-26-2017, 04:19 PM   #59
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
No worries, I wish I still had the re71rs. I killed them from not adjusting tire pressure, they were too high. :( the Star Specs were on sale, so I scooped them up.
And here's a picture that Caliphotography took.
Old 10-26-2017, 06:25 PM   #60
ArmstrongRacing
Data doesn't lie
Ive done that before, to my z2's. still got a to of racing out of them though. picture looks awesome man, i wasnt too pleased with mine
Old 11-12-2017, 04:17 PM   #61
atomic_hoji
Drives: 2018 Yaris SE 5MT
Nice update man.
Glad to hear all is well for both you and the car after your off - pretty sure I'd need a fresh set of underoos after a spin that like at a nearly a buck sixty..! lol
-- Adam
atomic_hoji is offline   Reply With Quote
Old 01-15-2018, 08:17 PM   #62
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
Not much of an update.
Ever since owning the car, the driver's side rear toe has too much toe in, it's off in the .30* range while passenger side is around .15* I'm surprised the off at Big Willow didn't make it more out of spec.
Rear:
Toe
L \ R
.30 \ .15
Camber
L \ R
-.7 \ -.9
I'm experimenting with shims because the idea of using just washers doesn't sit well with me. At least with shims, there is more surface area for the hub assembly to make contact with the torsion beam assembly.
These shims are cut out of .25mm shim stock. There are 6 pictured in the attach photo, but I only used 2 of these shims, and that was enough to kick the toe out from .30* to -.09*. I'm only using one shim now. I might have to pick up some .1mm shim stock and stack again. I really need an alignment rack in my garage.
#torsionbeamwoes
Old 01-15-2018, 10:58 PM   #63
Jason@SportsCar
Rear:
Toe
L \ R
.30 \ .15
Camber
L \ R
-.7 \ -.9
#torsionbeamwoes
No need for a rack, just get a set of Smart Strings and a Smart Camber gauge, never visit the alignment shop again. *especially important for those after off-track excursion checks in the paddock.
I did a similar thing, just bought different gauge stainless and cut shims to set the toe to zero.
http://www.smartracingproducts.com/
Old 01-16-2018, 12:52 PM   #64
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
I've been debating about running 0 rear toe, but since it is my daily maybe a little toe in for highway stability.
Either way, the smart string would be a good investment when I'm playing with shims. I feel it's going to be a steep learning curve for me initially. I figure once the bars are dialed in to the vehicle, future set ups will be a breeze.
Old 01-16-2018, 01:50 PM   #65
Jason@SportsCar
Zero in the rear is not an issue for street use - its more about reducing rolling resistance than changing the balance of the car.
Any time you use them on a new car for the first time it adds about 30 min just to dial in the bar setup, after that its easy. One of the best tools we ever bought.
Old 01-17-2018, 01:35 PM   #66
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
Alright Jason, you talked me into running 0 toe all around, and I also ordered the smart strings lol. I have some stainless 0.05mm shim stock coming, so it's going to be like playing with razor blades!
Old 01-18-2018, 05:43 PM   #67
ArmstrongRacing
Data doesn't lie
I did the same thing, 0 rear toe, and "some" rear camber lol
Old 01-27-2018, 09:53 PM   #68
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
Best use of an 18mm and 23mm socket.
Front and rear toe set to 0.
Old 01-29-2018, 12:01 PM   #69
ArmstrongRacing
Data doesn't lie
Very Nice!
Old 01-29-2018, 12:25 PM   #70
tmontague
tmontague's Avatar
Let me know what you think of the smart string, I may be interested in it down the road
Old 03-01-2018, 11:53 PM   #71
deng
Radical Dreamer
deng's Avatar
Drives: off of T9
Highly recommend the smart strings, I pretty much used it enough times to pay for itself.
Well, using the Yaris for HPDE has come to an end for now.
I received my start date at my new job location in Michigan in August, so I'm going to be busy with relocation these next few months.
Anywho, daily cross country spec. I tried going for that new school old school mash up, I like it.
Enkei Compe 15x7 +38
195/55R15 Yokohama Avid Envigor
Tsurikawa subway handle from my old drift car. I threw it on for fun. I think it looks pretty cool, but I'm not low enough for it to touch the ground.
I'm going to remove my Cusco Coilovers this weekend and swap in the factory struts/shocks with the R*SR springs that I still have. It should be more comfy with a little rise in the ride height (sadly lol).
Old 03-03-2018, 12:59 AM   #72
Runethecursed
Drives: 2009 Yaris S
Looks sharp sad to see you move to Michigan but its gonna be better living out there. I cant wait to leave the coast myself.
Runethecursed is offline   Reply With Quote
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 09:45 PM
I wanna make my Yaris a Type S beaker Cosmetic Modifications (Exterior/Interior) 2 10-06-2014 08:23 PM
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
Yaris T Sport UK Spec Mrgreengenes DIY / Maintenance / Service 0 10-01-2009 11:16 AM
