01-04-2007, 04:45 PM | #1 |
Drives: Black 2007 Yaris Liftback 1.5 Join Date: Jan 2007
Will this work?
I'm aiming for just a couple of small tweaks to the existing stereo system, keeping a stealth/stock look. Is this a viable plan?
Stock head Upgraded front speakers (probably MB Quarts installed as Coax) Stock rear speakers 150-200W amp driving four main speakers, mounted under rear seats Compact powered sub, also mounted under rear seat Is there anyting about the output options on the stock head that will prevent this from working? |
01-04-2007, 06:21 PM | #2 |
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US) Join Date: Sep 2006
Not that I know of. You're going to need a line out converter for the subwoofer.
01-04-2007, 07:09 PM | #3 | |
Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
01-04-2007, 07:45 PM | #4 |
would be fine, an LOC is no big deal.
I'd go with a component set up front though... the low door location of the yaris makes it tough to get the high frequencies up to ear level. |
01-04-2007, 07:52 PM | #5 |
With the sounstage set properly, the back fill speakers are the least important component and thus the ones that can most wait for a later upgrade.
And what made you think I was putting an amp, a sub and four speakers under one seat? |
01-04-2007, 07:53 PM | #6 |
Yeah, I might do that. I would really rather keep everything stock in appearance, but a couple of tweeters moutned on the door wouldn't be too terrible.
01-04-2007, 08:05 PM | #7 |
its EF LB 55
Component will sound much better than coaxial. Other than that it seems fine, replacing the rear speakers may be a worthy upgrade down the road but I have yet to found out if it fits where the stock speakers have. I think people have had troubles with that and it might throw off your stock look.
01-04-2007, 10:24 PM | #8 |
Drives: 2007 Yaris Liftback BBP Join Date: Oct 2006
Already did this, sounds great!!
I would change all speakers, when i removed mine to replace them i could not believe the size of the magnets (about 1"), The cheapest crapass speakers i have ever seen!! The stock head unit will do fine with a L.O.C., Check this thread for what I did. http://www.yarisworld.com/forums/sho...ght=fiberglass
01-04-2007, 11:23 PM | #9 | ||
Drives: 2007 Yaris S Join Date: May 2006
you should be fine keeping the rear spearers stock, but i would not power them with the amplifier, for they will not be able to handle the power... |
01-05-2007, 02:07 AM | #10 | |
your original post "150-200W amp driving four main speakers, mounted under rear seats Compact powered sub, also mounted under rear seat" If you meant to say 150-200W amp mounted under the rear seat driving the four main speakers, you probably should have! also the amp will need air flow to keep cool, as will the powered sub, how much room is under the rear seat in that hatch? I drive the sedan version. |
01-05-2007, 04:10 AM | #11 | |
Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
01-07-2007, 02:54 PM | #12 |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
there is a spot behind the seat between the plastic devider that seperates the trunk from the seat where amps and a couple clarion slim 10 subs will fit if you make a custom box. under the seat i doubt you could get all that to fit.
01-08-2007, 02:24 AM | #13 |
He may be able to fit it under the liftback's rear seats though.
Similar Threads | ||||
Who's At Work Rite Now? | David81 | Off-topic / Other Cars / Everything else Discussions | 43 | 02-20-2009 11:07 AM |
not safe for work thread | punch | Suggestions - Feedback - Questions | 25 | 04-21-2007 03:13 AM |
FS: Work Emotion CR KAI 17" | Hyde | Items for Sale by private party | 12 | 11-09-2006 05:50 AM |
06 RS 2 Door with some mods. (work in progress) | pegcityrs | Photo-Video-Media Gallery | 3 | 10-28-2006 12:12 AM |
How exactly does an heavier duty harness work? | IsLNdbOi | Performance Modifications | 5 | 09-26-2006 04:19 AM |
