04-22-2012, 11:09 AM | #1 |
Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Is it bad to coast in neutral....
While on the highway, I coast while driving towards the off ramp when I go to the gym. it's all down hill and my Ecometer has hit as high as 329mpg. I do it to amuse myself and to save gas, but I was wondering if it's bad for the tranny to coast in neutral?
Thanks. |
04-22-2012, 11:13 AM | #2 |
No it is not bad for the tranny. If you really want to have fun with the ecometer, try coasting while in gear. If you can hold the engine to above 1100rpm (I think that is the number) without pressing on the gas petal, DFCO kicks in and no fuel is being used. Once engine idle drops below 1100, fuel is being fed to the engine.
04-22-2012, 12:46 PM | #3 |
Form>Function
Beat us all to it lol ^
OP- there is a sticky on this http://www.yarisworld.com/forums/showthread.php?t=4248 |
04-22-2012, 03:44 PM | #4 | |
Drives: '08 Yaris LB Join Date: Jan 2012
You're also putting additional wear on the brakes too since you are losing any compression braking effect. But its your car so go nuts! |
04-22-2012, 04:38 PM | #5 |
Drives: 2010 black yaris Join Date: Oct 2010
OH GEZUS, NOT THIS THREAD AGAIN!
NOOOOOO
04-23-2012, 08:40 AM | #6 |
Thanks, guys. I hit 349mpg this morning. Oh yeah....
04-23-2012, 11:41 AM | #7 | |
Only Happy When it Rains
Colin Chapman disciple |
04-23-2012, 12:20 PM | #8 | |
Even the sticky thread in the FE forum says to leave it in gear? |
04-23-2012, 01:08 PM | #9 |
Drives: 2008 XP9 by Sparco Join Date: Nov 2011
04-24-2012, 10:33 AM | #10 |
Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
last standard i had was a 4 cylinder nissan frontier truck and i used to coast in neutral a lot. i had to replace the throwout bearing at just over 100,000 miles and i always wondered if it was due to coasting in neutral.
04-24-2012, 12:16 PM | #11 |
What does a throwout bearing have to do with coasting in neutral?
It only wears when your pushing the clutch pedal. |
04-24-2012, 04:57 PM | #12 |
here we go again. There are only two instances where leaving the car in gear will get you better gas mileage, if you are going down a steep enough hill that the car keeps the acceleration anyways, or if you are slowing down to a stop anyways. On a flat road leaving the car in gear will get worse mileage than putting it in neutral will, because you will have to hit the gas pedal more with the engine sucking the energy out of your forward momentum.
In reality a combination of both is the best to get the best gas mileage, depending on the situation you are in and the traffic, etc.
04-24-2012, 05:18 PM | #13 |
Coasting will never save you gas if you don't intend to stop or at least slow down. The best way to get from a to b is at a constant speed. Just coasting and then accelerate to your previous speed is useless
04-24-2012, 06:20 PM | #14 |
This is totally false, as countless thousands of hyper milers have proven beyond a shadow of a doubt.
05-01-2012, 11:58 AM | #15 | |
Drives: 2007 Yaris Hatchback Join Date: Jan 2011
this is a pretty narrow minded way to look at this, and may encourage people to look at this the wrong way let me re-word what you're saying: always leave the car in the most optimal gear, except for when you're just about to go below 1000PRPM in first and stop. doing this, will ensure you will have the best MPG possible, as being in neutral never helps your MPG |
05-01-2012, 01:05 PM | #16 |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
I am not questioning the DFCO issue but while I was on a long downhill glide, the gas gas dropped a level. I was in Drive and my foot of the gas pedal, so if it doesn't use any gas, why did the gas level drop? Couldn't have been the angle of the road or car on the road because that was a constant. There has to be some gas being used for the gauge to register a drop in fuel.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! |
05-01-2012, 01:37 PM | #17 |
because your gas tank ain't level no more the sensor may measure a lower level.
05-01-2012, 08:07 PM | #18 | |
Similar Threads | ||||
Q: when shifting into neutral... clutch? | yarisugi | General Yaris / Vitz Discussion | 31 | 04-19-2012 10:51 PM |
8.9 Earthquake off the coast of JDM land ..ie Tsunami! | rningonfumes | Off-topic / Other Cars / Everything else Discussions | 28 | 03-25-2011 09:59 PM |
Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
So Close!!!! | aclark246 | Fuel Economy Forum | 13 | 06-07-2009 10:02 AM |
The Official Having A Bad Day Thread. | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 7 | 11-15-2008 08:38 AM |
