Old 06-16-2017, 05:55 PM   #55
tmontague
2zr-fe dream team
tmontague's Avatar
Drives: 08 Vios M/T, 05 4wd Vibe
No issues with the xd cables as they are longer. You can use the Yaris cables with the Yaris dogbone (i originally did) but because I want a long tube header I wanted more room at the fire wall so I installed the xd dogbone. This moves the engine forward more which than stresses one of the Yaris cables. Xd ones have no issues
2zr swapped Vios, oil catch can, TRD rear sway bar, MI lowering springs, In cabin+under hood SSK, TRD shift knob, HID projector/Halo lights, 10mm rear axle spacers, custom header back exhaust, Front splitter, Sickspeed dual horns, Tokiko Blue's in rear, triple gauges, Whiteline bushings, Sparco pedal covers, Viper Keyless entry, DC Sports CAI, NST u/d crank pulley, solid poly engine mounts, MR Racing Flywheel, Konig Dial Ins 15x7 +35
Old 06-16-2017, 10:41 PM   #56
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by heeroyuy01195 View Post
Have you had any issues with the "under hood" SSK and the xD cables?
The engine bay SSK is starting to wear on my setup after about 5 or 6 years. I've only greased it once or twice, so that is probably a contributing factor. The cable length isn't perfect, but it fits well enough with the SSK bracket.
Old 06-16-2017, 11:18 PM   #57
heeroyuy01195
Post count means nothing.
Thanks for the info montague and cranky, saw that Garm has a few SSK's for sale on his ebay store but wasn't sure how it would play with the swap later on. Looks like I'll be picking up one of his kits; my NST never felt right.
heeroyuy01195 is online now   Reply With Quote
Old 06-16-2017, 11:22 PM   #58
tmontague
2zr-fe dream team
tmontague's Avatar
It probably never felt right because they never made a bracket to replace the one bracket that bolts to the trans and hold the cable ends.
Garm is the only person I know of who has/had them and they change the angle that the cable where it attaches to the shift levers and makes for smoother shifting
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
