04-22-2018, 12:27 PM | #1 |
Drives: Yaris Join Date: Apr 2018
Can it fit?? 17 - 7.5 ET 35
Hi guys. I Got a third generation Yaris and i looking for a new set wheel and i have found KW series s11, but my problem is that there is 7.5 width with ET 35,
My question is Will it fit in the front ?? Hope some one out there Can help me😃😃 |
04-22-2018, 01:52 PM | #2 | |
04-22-2018, 11:33 PM | #3 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
it will fit fine. use the calculator
https://tiresize.com/wheel-offset-calculator/ |
04-23-2018, 05:42 AM | #4 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
If you're not lowered then it should fit fine. If you're lowered you will probably need to run some negative camber to avoid rubbing
No one ever wants to give a Yaris the point by... |
04-23-2018, 02:51 PM | #5 |
I not sure how to use the calculator, 😔
I have lowered a little bit, not so much. I Will buy the and hope it Will fit. Thanks a lot guys 😃 |
04-23-2018, 02:53 PM | #6 |
Be sure to update here if you do get them. Give us more info on what happens when people go to the limits of wheel width and offsets. Like I said, I believe you will be borderline.
That calculator doesn't really help when it comes to figuring out if you will buzz the wheel wells if you bottom out the suspension. You probably will experience this in the rear end.
04-23-2018, 08:51 PM | #7 | |
-stock wheel/tire size is 185/60/15 offset +45 -enter in those numbers into their respective locations -enter the new size; you didn't specify, i guess, 205/45/17 offset +35 beep-bop-beep-bo-beep the tire sticks out .8 inches (20mm) from stock. the inner sidewall is .01 inches (.25mm) closer to the engine bay. the tire is taller, .3 inches (7.6mm) closer to the top of the wheel well. if you go with a 195/45/17, your stick-out drops to .59 inches (15mm) |
04-24-2018, 06:22 PM | #8 |
wavy
https://www.willtheyfit.com/ use the stock yaris oem rims specs and stuff. input theres a guestimate. |
Similar Threads | ||||
Test Fit $50 Or LED Tail lights | winson | California | 6 | 01-05-2010 08:31 PM |
Sorry guys, I bought the Fit. | john21031 | Off-topic / Other Cars / Everything else Discussions | 39 | 12-29-2009 03:53 PM |
Why does everyone compare the Yaris vs Fit... | b_hickman11 | General Yaris / Vitz Discussion | 71 | 03-03-2009 09:57 PM |
test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
Will honda fit rims fit on a yaris. Meaning are the hubs the same bore? | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 12-24-2008 03:09 PM |
