Old 09-25-2015, 02:44 PM   #1
tomm9050
Drives: Yaris 2008 HB
Spark plug gap?
What should the gap be on denso SK16R11 plugs for a 2008 HB?
thanks
tomm9050 is offline   Reply With Quote
Old 09-25-2015, 06:48 PM   #2
1.1mm, which is what those plugs come pre-gapped as. Iridium plugs come pre-gapped, as you can easily scrape or crack off the coating while gapping them.
Old 09-26-2015, 12:02 PM   #3
MUSKOKA800
MUSKOKA800's Avatar
Drives: '08 Yaris Sedan, Aero Package
NGK adds the suffix '-11' after the regular plug number for the plugs gapped specifically to our specification. This leads me to believe that any without the -11, which I see at auto parts stores, may be random gaps or at least another spec.
The 11 at the end of the Denso number indicated above may be a similar code.
Old 09-26-2015, 12:43 PM   #4
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
11, makes sense to me
Old 10-23-2015, 12:27 PM   #5
tomm9050
Thanks !!
Old 10-23-2015, 11:21 PM   #6
xdarkxfirex
Drives: 2015 yaris le
.044
xdarkxfirex is offline   Reply With Quote
Spark plug gap for 04 echo donnysdayoff DIY / Maintenance / Service 2 01-16-2014 08:56 PM
bit of spark plug insulation may have fallen into cylinder alagappan the proud DIY / Maintenance / Service 20 01-09-2014 06:10 PM
Spark Plug Gap sleey0 Forced Induction Forum 7 09-21-2010 05:47 PM
spark plug gap Hard_Yaris DIY / Maintenance / Service 2 06-10-2010 05:23 PM
Plug Gap slvryaris DIY / Maintenance / Service 1 12-23-2008 10:02 PM
