Old 03-12-2018, 02:29 PM   #1
funky2nite
Drives: 2013 Hybrid 1.5L T4
Yaris hybrid '13 - operating key manually in door doesn't work
Since we bought the car, serviced it and cared for it over the past year. Today it crossed my mind to try the door lock by using the key instead the remote central lock. Key turns in the door both sides, but to no avail.
Could it really be a failed door actuator? The car's is still in its early life 14k miles, should i look at something else before narrowing it down to failed master actuator? Remote central lock works flawlessly and operating the driver door central lock buttons on the door card works fully too both to lock and unlock. Just the key from outside the door, i have a genuine key that came with the car and a copy one. Both are able to start and drive the car, but none will open the door manually from outside, just with central lock one is able to access the inside of the car...aka central lock fails (battery dies etc) i'll be stranded outside the car....for good
Would appreciate any thoughts guys,
Thanks everyone
funky2nite is offline   Reply With Quote
Old 09-29-2019, 04:09 PM   #2
funky2nite
This was fixed, by taking off doorcard, apparently when the door was sprayed due to a minor hit, assembly wasn't proper and the key lock prong wasn't fit in the right assembly so basically turning the key Externally was literally actuating thw lock prong in empty space, instead inside of the door lock assembly to lock/unlock the car
central lock, central locking
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
2007 Yaris Keyless entry key kev084 DIY / Maintenance / Service 1 07-03-2012 12:24 PM
2007 Yaris Keyless entry key kev084 DIY / Maintenance / Service 0 07-03-2012 07:23 AM
