Old 03-15-2018, 04:33 PM   #1
Yaris709
Drives: 07 yaris
Having brake issues
Having issues with the brake pressure in my 2007 yaris sedan. When I first start up the car I have no brake pressure and can't stop. Once i get going down the road a bit the brakes work perfect again. Seems to only happen for a few seconds after start up and driving. Anyone have an idea what could my problem be?
Yaris709 is offline   Reply With Quote
Old 03-15-2018, 07:16 PM   #2
ex-x-fire
So, you don't have any power assist?
ex-x-fire is online now   Reply With Quote
Old 03-15-2018, 08:05 PM   #3
Yaris709
Drives: 07 yaris
Nope I loose break pressure (and car can't stop) for a few seconds on a cold start of the car. After driving for a few seconds it seems fine again
Old 03-16-2018, 07:02 AM   #4
ex-x-fire
I guess you can look for wet spots anywhere. My guess would be the master cylinder is bypassing.
Old 03-16-2018, 12:41 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
Is the brake pedal hard, or you push and it goes to the floor?
Old 03-16-2018, 01:46 PM   #6
Acura_reaper
Drives: 2007 silver auto stock sedan
I just rear endend a focus yesterday cuz my brakes went to the floor. Broke my grille but did nothing to their car go figure.
Sent from my VS996 using Tapatalk
Acura_reaper is offline   Reply With Quote
Old 03-16-2018, 01:48 PM   #7
IllusionX
Then your master cylinder must have issue IMO.
Old 03-16-2018, 01:57 PM   #8
Acura_reaper
Ill have to check it. I replaced my front brake pads bled the brakes snd checked fluid and lines it looked good. it seems a lil bit stiffer but my pedel is spongy.i dont know. Their really ait much else it could be. Maybe back brakes idn
Old 03-16-2018, 02:02 PM   #9
IllusionX
Pull hand brake if you are not getting brake response...
IMO you shouldn't have driven your car when you knew you had brake problems.
Brake fluid should be changed after a while AFAIK.
Old 03-16-2018, 03:43 PM   #10
Acura_reaper
Your right but when you have to go to work you go to work
Old 03-16-2018, 04:21 PM   #11
IllusionX
No you don't, or you find another way to get to work and not put others or yourself in danger.
Old 03-16-2018, 04:37 PM   #12
Acura_reaper
U dont know my situation so stop trying to tell me what i should do and help me fix my brakes or shut up
Old 03-16-2018, 04:46 PM   #13
IllusionX
Garage. Check master cylinder. Told you already.
What if you just FUCKING DIED while going to work with a broken car? Hope you kill someone with your car.
Old 03-16-2018, 08:20 PM   #14
Yaris709
Drives: 07 yaris
Alright guys enough with the arguing haha I'm just wondering why my cars brake pressure was temporarily lost for a few seconds. On a side note it was fine today never had any trouble at all. This is a weird problem
Old 03-17-2018, 08:43 AM   #15
dogsridewith
Drives: 2007 2-door hatchback
Yaris brakes malfunction
OP will get better advice here if e answers this question. (A pedal on the floor or a high pedal w/ failed boost will both reduce "brake pressure," but would likely have different causes.)
Old 03-17-2018, 08:51 AM   #16
IllusionX
High brake is likely failed vacuum, but a pedal to the floor is either air in system or master cylinder.
Now, op already checked for brake line leak, and bled. Provided he did good/proper maintenance, all I can think of is the master cylinder having issues.
Eitherway, OP said his pedal went to the floor, I did suggest it was the master cylinder, stop driving the car as it is very dangerous.But well, looks like I know nothing, so I'll just let OP drive his car around trying to kill some innocent people
Old 03-17-2018, 10:37 AM   #17
Please note that there are two individuals with brake issues contributing to this thread.
The OP did not make the statements you are referencing.
Old 03-17-2018, 10:40 AM   #18
IllusionX
Nice thread hi-jack. SMH
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Help! Brake light issues! Prohibit DIY / Maintenance / Service 17 05-23-2011 07:33 PM
Rear brake adjust issues 07 Hatch Tardis DIY / Maintenance / Service 4 03-20-2010 05:49 PM
