Old 03-31-2022, 07:38 AM   #1
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
04 Echo won't cold start.......
Hi Guys,
after trying just about everything I am reaching out to see if anyone can help.
I had a car that started fine, then I swapped the throttle body with a new one, then all of a sudden I have to idle it up with the gas pedal when its below 70 deg water temp. The car starts but will die right after unless I give it some gas, then it will run and as soon as it hits 65-70 deg C it will idle.......
The car is not going into cold start mode........
I have put a brand new ICAV in and the car does the exact same thing.......I have checked the voltage from the wiring harness as well, 12V when cold, so the ICAV should be working........
any help here would be appreciated.......
Ronnie V is offline   Reply With Quote
Old 03-31-2022, 09:04 AM   #2
ex-x-fire
Did you unhook the battery for a while to clear the computer's memory?
Old 03-31-2022, 02:32 PM   #3
Ronnie V
Yes, had the battery out of it all winter.
Old 03-31-2022, 07:29 PM   #4
ex-x-fire
Any possible vacuum leaks?
2005 Echo stutters, stalls, hard start OblivionCore DIY / Maintenance / Service 5 02-13-2018 10:44 PM
2002 Echo Crank, No Start, No Spark, Immobilizer Katooshy DIY / Maintenance / Service 27 02-10-2016 04:02 PM
Yaris sedan sputters after a cold start!! CT Scott pls help if you're out there!!!! tyrone_yaris DIY / Maintenance / Service 32 12-03-2012 02:00 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 02:20 PM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
