Old 04-07-2024, 10:22 AM   #1
vollnormal
Drives: Yaris
Fuel leaking from tank breather tube
Hi all,
I've encountered an issue where fuel is leaking from my fuel tank breather tube. Notably, the bottom tube from the charcoal canister has rusted through, although this has been the case for years, so it can't be the cause.
Any suggestions on what might be causing fuel to come out of the breather tube would be much appreciated?
It is a 2006 yaris with a 2SZ-Fe engine.
Any help would be appreciated!
Thanks!
Matty
vollnormal is offline   Reply With Quote
Old 04-08-2024, 12:14 AM   #2
komichal
I guess you may have been loading too much fuel into the tank. One click of the gun is enough.
But I had exactly the same problem, without overloading the tank. Except my car is rusty af everywhere so I just had it replaced (not expensive).
Looks like some problem that can simply occur after many years of service.
Old 04-08-2024, 12:16 AM   #3
komichal
Here is my rusty turd. https://yarisworld.com/forums/showthread.php?t=64893
Seriously man, your car is in mint condition when comparing to mine.
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 324 02-29-2024 06:43 AM
Fuel leak close to the tank komichal DIY / Maintenance / Service 5 07-25-2023 04:48 AM
Car runs better with full fuel tank komichal DIY / Maintenance / Service 1 12-11-2022 12:18 PM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 03:20 PM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
