10-17-2018, 04:49 PM | #1 |
Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Manual tranny Yaris
I might have a chance to buy a manual transmission 2010 Yaris. Before I do so, anything I should know about any potential problems with this type of transmission in the Yaris? How do those who have the manual transmission in the Yaris like it? If I do this, I'll be passing my current Yaris onto my nephew and keeping this one for myself.
Thanks. |
10-17-2018, 09:12 PM | #2 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
uh..it's pretty okay. i haven't had issues. i got mine at 60,xxx miles, changed the oil with royal purple 75w-90. that was...2 years ago (?) i'm at 100,270 today. still feels the same as when i changed it. i will probably change it again soon with something formulated for MT, or redline 75w-90.
the only issue i have is getting into 1st gear wile rolling, like in traffic; slowing for a red light that turns green and i'm at like 6 or 7 mph. it does not want to go into first and i have to start in 2nd all slow... or it grinds into 1st. i think there might be a clutch issue though. it might be super worn, and there might be a bubble in the line. to my knowledge it is the original clutch... |
10-17-2018, 10:43 PM | #3 |
Thank you, SirDigby.
10-18-2018, 08:03 AM | #4 |
Drives: 2010 Yaris - Blazing Blue Join Date: Aug 2011
I have a 2010, currently sitting at 190,000 miles with original clutch and everything. I wouldn't hesitate.
10-18-2018, 10:44 AM | #5 |
manual yarii are solid. its a 2400lb car....you REALLY have to hamfist it to break it.
i never broke mine and i was boosted and i used to auto-x and lap it. my echo has 240k miles on it and its fine, too
10-18-2018, 01:38 PM | #6 |
Drives: 2007 2-door hatchback Join Date: Jul 2016
Toyota Yaris stiff shift first gear bleed double clutch synchro
My 145k mile 2007 is so stiff into a slow rolling shift to first that I consider this to be an obstacle to the car being a good rock crawler. (Low front bumper cover is another.) It would be entering a slow steep climbing section for the 2-1 shift, and the car would be stopped by the time a double-clutch was finished!
It isn't the clutch. They do engage down near the stop, but I got a bit of height and some gritty brake fluid by bleeding when I first got the car. Test drive before buying to find grinds, stiffness and/or clinks in all the 2 through 5 upshifts and downshifts. |
10-19-2018, 06:56 PM | #7 |
Drives: 09 Yaris hatchback Join Date: Sep 2018
My '09 with ~120k miles does not have any issues if I get a rolling start into 1st (in fact, I downshifted into 1st while climbing up a hill the other day.) I don't think the clutch has ever been replaced, because the previous owners said they bought it with 20k miles.
The one weird thing is it feels like it grabs twice and slows down really fast in 1st and 2nd when I let off the gas. I'm thinking this is because of the decelerative fuel cutoff. Does anyone else experience this? It's kind of inconveniently jerky when I'm trying to coast along in traffic at 2-3mph with the clutch out and giving the gas light taps. EDIT: it also has no tach which is a bit challenging because it's my first manual car. I'm surviving though. |
10-19-2018, 08:31 PM | #8 |
I think mine may have some of that jerk in throttle transitions from driving to engine braking in first gear. Could be in part due to naturally soft engine mounts and worn mounts. I still get some chatter starting in reverse sometimes.
10-20-2018, 08:23 PM | #9 |
2ZR swap. DO IT! Ask how!
For your average commuter that doesn't push it to the limits and understands how to shift, it's rock solid. I've been beating on mine for the last 5+ years, went boosted and now have the 1.8L swapped in. No mechanical issues to report from the gearbox.
10-23-2018, 03:10 PM | #10 |
You have to rev match to first. I have no problem getting into first in mine.
10-23-2018, 03:15 PM | #11 |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
just start in first gear and let go of the clutch and add the gas.
10-26-2018, 05:08 PM | #12 |
Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Manual transmission is the norm in the UK and Europe. First time i drove an auto was a hire car in Canada when i was 23.
I've been driving my 5 speed Yaris for 7 years, i changed the clutch last year at 130,000 (i think) miles although the clutch had been abused a little. Only thing i notice is sometimes it takes 2 attempts to get into reverse sometimes, like the syncros are not quite grabbing. Normally clutching again and it will go in. Same every now and again where it won't go in first. I've seen other Toyota gearboxes behave the same way. Normally clutching again it will go in fine. I've actually driven a Corolla that suffered a catastrophic failure of 3rd/4th and reverse gear for a week and i managed with driving that around. I'd never want to drive an automatic. Currently running a "rot gut" 75w90 semi synthetic GL4 gearbox oil made by Comma in my gearbox and it seems fine.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
10-31-2018, 11:27 AM | #13 |
Reverse doesn’t have syncros . Sometimes you need to double clutch in order for things to line up to get it into reverse.
10-31-2018, 12:33 PM | #14 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
It's normal for a m/t car to "buck" in first gear. If you want to roll in traffic in 1st then you'll have to press the clutch pedal
No one ever wants to give a Yaris the point by... |
11-05-2018, 02:55 AM | #15 |
Drives: 2011 Yaris Sedan Join Date: Mar 2017
11-05-2018, 05:58 AM | #16 |
These stiff-when-rolling first gears in the 5-speed manual--did anyone have one like that when the car was brand new? Did anyone have one where the rolling 2-1 shift-shifting got easier over time/miles?
11-05-2018, 09:34 AM | #17 | |
Drives: No longer own a yaris :( Join Date: Mar 2012
Also, it's fun....and you can combine it with heel-toeing and put on some eurobeat and go to down like Takumi Fujiwara. |
11-05-2018, 06:05 PM | #18 | ||
I don't remember how it was when new, it's been 12 years lol I'm at about 110k miles Sent from my CLT-L04 using Tapatalk |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
2018 Yaris SE 5MT - T-Sport w/Valvematic! | atomic_hoji | Performance Modifications | 130 | 02-23-2019 11:56 AM |
2YR/25K Retrospective/Review (French-Built 2015 Yaris SE, Manual 5-spd) | Kalispel | Third Gen Yaris General Discussion | 12 | 08-24-2017 11:26 AM |
Yaris 2011 repair manual. | gitmoyaris | DIY / Maintenance / Service | 2 | 08-22-2017 11:10 PM |
07 yaris 4d4 automated manual serious issues | maximapitko | DIY / Maintenance / Service | 3 | 07-04-2010 12:46 PM |
