Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Central and South America
Old 12-06-2012, 09:16 PM   #37
Looking at the Service Manual in regards to the expansion valve, I found the following, which sounds a lot like your problem.
Condition:
Air conditioning system periodically
cools and then fails to cool.
Cause:
Moisture in refrigeration system
freezes at expansion valve orifice,
causing temporary interruption of
cycle. However, when melted, returns to
normal condition
Diagnosis:
Receiver dryer oversaturated
system freezes at expansion
valve orifice and blocks
refrigerant circulation
Old 12-07-2012, 06:04 AM   #38
jeoc27
Drives: Yaris 2006
ok, I'll send to the pipe with a clean sweep, make empty and then load the new gas
jeoc27 is offline   Reply With Quote
Old 02-27-2013, 11:27 PM   #39
jeoc27
Drives: Yaris 2006
hello me again, change the compressor and the problems persist, the technician told me that the fault current appears because it works well and seems to be working at the time of the cold decreases because the lower the voltage generator that sends and causes the lower fan speed and thus their high blood pressure to rise and leave to cool, is this possible?
Old 02-27-2013, 11:46 PM   #40
jeoc27
Drives: Yaris 2006
Old 02-28-2013, 01:48 PM   #41
jeoc27
Drives: Yaris 2006
Old 02-28-2013, 01:56 PM   #42
It could be that the pressure switch is bad. It would be great to get a Toyota Techstream tool connected to your car to read the error codes and live data from the AC computer.
Old 03-03-2013, 01:41 PM   #43
jeoc27
Drives: Yaris 2006
to remove the exhaust air begins to chill well
Old 03-03-2013, 01:41 PM   #44
jeoc27
Drives: Yaris 2006
Old 03-11-2013, 05:23 PM   #45
jeoc27
Drives: Yaris 2006
hello friend, the voltage must receive the compressor?
Old 03-11-2013, 10:59 PM   #46
The compressor gets 12 Volts on the green wire to engage the compressor.
Old 04-07-2013, 11:48 AM   #47
jeoc27
Drives: Yaris 2006
hello, condenser and evaporator cel my yaris and now cooled cooling well but leaves soon after and note down the pipe is not cold but rather sweaty
Old 04-07-2013, 11:48 AM   #48
jeoc27
Drives: Yaris 2006
Hello, you change the condenser and evaporator compressor yaris and now my cooling fine but stops cooling soon after and note down the pipe is not cold but rather sweaty
Old 08-19-2017, 04:37 PM   #49
Wilfred087
Drives: Toyota yaris sedan
No enfria en baja
Buenas tengo un problema tengo un yaris sedan 2007 cuando el carro esta parado no enfria el aire pero si lo acelero un poco empieza a enfriar alguien sabra el por que? Me disen que puede ser la poa pero que quisas no! Alguen que me pueda ayudar
Wilfred087 is offline   Reply With Quote
falla en aire acondicionado frank_0124 Central and South America 4 07-28-2013 07:54 PM
TENGO UN PROBLEMA casi serio con el carro ryas Central and South America 18 11-07-2011 03:22 PM
problema con fog light hid rene0023 Caribbean 29 11-25-2010 02:12 PM
problema con yaris yaris_trd Caribbean 44 09-14-2010 10:28 AM
Filtro del Evaporador del Aire acondicionado joseorellana2012 General Yaris / Vitz Discussion 2 07-17-2009 07:41 PM
