Old 11-18-2017, 10:42 PM   #19
kimona
kimona's Avatar
Drives: 2014 White VITZ
What did you buy?
Old 11-19-2017, 07:08 AM   #20
dogsridewith
Drives: 2007 2-door hatchback
Corrosion Block suspension bushings creak rust salt dot5 silicone
My SoCal 07 developed a suspension creak (like when the driver opens the door and sits down) after a year in over-salted PA. Before first winter, squirted many external and under-hood body seams w/ green color "Corrosion Block." Last week put the winter treads on and added all suspension pivots and visible metal fasteners to the routine.
Not enough use yet to say creak is gone...but it might be.
Can't say CB won't hurt rubber, wire, and electronics. But web blurb of Florida company that sells it seemed to imply it might be OK. Smells better than spray mix of new oil cut with old gasoline.
(Have also experimented w/ dot5 brake fluid on suspension pivots of two other vehicles.)
Did OP try lube on the A-arms (lower control arms whatever they're called)pivots/bushings?
suspension
Front suspension noise RicStyx Third Gen Yaris General Discussion 3 08-25-2017 09:50 AM
Colour Collection 05 Reg (UK) brake noise JLx DIY / Maintenance / Service 0 07-14-2015 06:56 AM
'02 Echo Suspension clunk fix tmontague DIY / Maintenance / Service 5 06-29-2015 11:02 AM
WTB: Front suspension bits advocate Willing to Buy by private party 4 08-11-2011 10:39 AM
Front end suspension making "Creaking Door"noise! Need help! Syroyizhka Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-03-2009 07:55 AM
