Old 03-21-2013, 01:33 PM   #1
frankieschl
Drives: 2007 toyota yaris
Fuse panel
I have a 2007 Yaris and the entire fuse panel under the dash is out except for the (2) 7.5 fuses which i think is the ignition and not sure of the other. Does anyone know if there is a main fuse or relay that controls the entire panel under the dash?
frankieschl is offline   Reply With Quote
Old 03-21-2013, 01:54 PM   #2
Yes - The 60A MAIN fusible link on the positive terminal of the battery feeds the majority of that fuse box. It is built into the black plastic chunk that sits under the red cover.
Old 03-21-2013, 04:45 PM   #3
frankieschl
That is it. where can I get one now is the problem lol. Thanks for your help.
Old 03-21-2013, 04:51 PM   #4
That is pretty much a dealer or mail order part only, that whole plastic block has to be replaced.
Old 03-21-2013, 04:53 PM   #5
frankieschl
is there any way i can make my own fusible link like that out of parts from autozone?
Old 03-21-2013, 05:26 PM   #6
You basically need to bridge the popped fuse with the guts of an equally rated fuse. You would have to trim back the existing one a bit and then solder the new one to the two ends of the old one.
Old 10-15-2022, 09:58 AM   #7
Navigator17
Drives: Toyota Yaris 2011 NCP90
Yaris 2011 Fusebox Cover in Engine Bay
Hi Yaris Lovers :)
Hope you are doing great.
I am looking for Fuse Box Cover for my Yaris 2011 NCP90 , it resides inside the Engine Bay but the Cover is not there - Can you please guide me here where i can get this part from or anyone on this forum selling this ?
Attached image shows how the Fuse Box Looks
Navigator17 is offline   Reply With Quote
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 06:53 PM
DIY rear Interior panel removal 09 3dr LB bkndacn Cosmetic Modifications (Exterior/Interior) 10 03-11-2013 01:05 AM
Instrument Panel Fuse box location?: Yaris T3 Spirit tony005 DIY / Maintenance / Service 3 06-22-2012 10:10 AM
where is the friggin fuse panel? darkMINI DIY / Maintenance / Service 4 08-11-2010 03:24 AM
