09-14-2017, 03:10 AM | #1 |
Air whining from front windows
Hi folks,
I am not traveling that much on highways but when I do, I always notice (at speeds above 100 km/h (70 mph)) a whinning noise from either left or right front side windows. It sounds exactly like if you do not close the window completely but leave 1mm space between the window frame and the glass itself. Annoying whistle... But visually the window goes well inside the sealing. My front windows are controlled electrically. When the annoying sound starts to whine and I pull the button to "close the window that is already closed" then the window moves up like 0.2mm and the noise is gone. But once I release the button the noise returns back in 2 seconds or so. So I suppose the window sealing in the door frame is worn out but the new one seems pretty expensive, not to mention the fact that I am not sure whether I can see the right one in the catalog (plus I have no clue how to change it). Is there a way to somehow adjust the electrical control to close the window tighter? Or do I need to glue some thin seal onto the top edge of the glass? That would look ugly... I also tried to lubricate a bit the seal with silicon oil to allow glass to go a bit deeper. That did not help much. Any thought would be much appreciated, thank you in advance! |
Similar Threads | ||||
The front brake upgrade thread - just the facts | brushforhire | DIY / Maintenance / Service | 35 | 04-07-2022 07:07 AM |
DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 53 | 11-12-2017 03:03 PM |
2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
