Old 01-19-2012, 11:14 AM   #1
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
Why my PCM try to lean the mixture at idle?
Hi All,
I've posted before about sub-par fuel mileage on my 08 liftback. I have been trying to pinpoint the issue and there's one thing in regards to that.
So I hook up an obdII scanner (well it's a bluetooth adapter and Torque on an Android phone...neat) and see consistent negative long term fuel trim at idle. Most of the time it's at -7%. Under any kind of load the numbers are closer to 0.
Here's a typical idle screenshot:
Overall the car drives fine. The measured air fuel ratio is around 14, the commanded ratio is about the same.
Things that have been done recently:
- air filter
- tb cleaning (had some deposits)
- new spark plugs (black base ring on the original ones...rich condition? pic here: http://i425.photobucket.com/albums/p...5700548578.jpg ) New plugs are NGK iridium.
- new PCV valve (oem).
- reset the PCM a couple of times...fuel trim crept back to -7% pretty quick.
Any ideas?
Thank you.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
Idle Fluctuation due to aftermarket intake? Galavoxx Performance Modifications 38 12-31-2011 08:31 AM
Lean Burn - Hydrogen Enrichment GeneW Fuel Economy Forum 20 07-23-2010 02:59 PM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 08:23 AM
