Old 04-24-2014, 12:02 PM   #1
csrblanco
Drives: Toyota Yaris 1.4 D4D 2006 MMT
Yaris, very mysterious, electrical problem (VIDEO) - SOLVED
Hello, I am having a big electrical problem with my Yaris 1.4 D4D 2006. As you can see in the video, when driving suddenly everything start to blink, gear change to Neutral, radio off, and some seconds later everything works again.
Is impossible to reproduce the problem, that occurs from time to time, not always.
Tha battery is well connected and seems to be OK (at least green light in the battery hole and not problems to start).
I appreciate a lot any advice.
https://www.youtube.com/watch?v=FB8ZSdRJFtU
Regards
csrblanco is offline   Reply With Quote
Old 04-24-2014, 12:31 PM   #2
marauder
marauder's Avatar
Drives: '08 Yaris
Check the ground wire to the chassis, not at the battery. Have you changed anything electrical recently? Headlights, stereo, etc...
marauder is offline   Reply With Quote
Old 04-24-2014, 12:45 PM   #3
csrblanco
Thank you marauder.
Nothing, I've never change or install anything.
Old 04-24-2014, 02:23 PM   #4
marauder
marauder's Avatar
Drives: '08 Yaris
Could be a simple fault in a ground wire to the engine, etc...
Look up technique for testing your vehicle's earth/ground system for faults. Try this article, see if this helps you any. http://www.popularmechanics.com/cars...enance/4314662
Old 04-24-2014, 02:59 PM   #5
csrblanco
Great. Thank you. I will have a look to that info.
Old 04-24-2014, 09:05 PM   #6
Besides checking for loose ground connections, check the connectors on the under side of the positive battery terminal to make sure they are not loose or corroded.
Old 07-09-2014, 04:05 PM   #7
csrblanco
SOLVED. The problem has been solved just with a new battery. It seems the old battery don't have enough power to support all the electrical demands.
Thank you!.
Supercharged Yaris: Greatest Yaris video ever made. TRUST ME! PETERPOOP Photo-Video-Media Gallery 54 08-29-2013 03:27 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Electrical System problem 2006 Yaris Ivriniel DIY / Maintenance / Service 12 05-10-2010 02:55 AM
