Old 10-25-2014, 12:58 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Engine Rock and Roll.
So I think I've wrecked my motor mounts. I have to admit, since I've installed my Blitz (Thanks again Tolmach, CTScott, and Cali Yaris), I have developed even more of a lead foot. Do the factory motor mounts allow the engine to move fore and aft quite a bit (2-3")? If so, is there a solution to tighten them up a bit? If not, are there replacements that are stiffer but not solid? I've been tempted to take them off and re-bush them with polyurethane as well. Any thoughts on that route?
07stlYaris is offline   Reply With Quote
Old 11-22-2014, 01:05 PM   #2
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Maybe a video of unwanted motion to help. But, I am thinking, maybe a home made torque strut somewhere appropriate would help.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
Old 11-22-2014, 08:46 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I doubt you ruined them, the engine is suppose to move a lot. If you look, even the piece that connects the exhaust to the block is flexible.
Colin Chapman disciple
