Old 02-04-2018, 03:43 PM   #1
perro547
Drives: 1
Rear veiw camera install help
So I'm trying to install a rearview camera on a 2015 Yaris le. Those 2 bolts that hold the plastic cover in piece for the camera cutout won't come out. It just keeps spinning but does not get looser ?? I've been trying for a while and no progress. Also I'm trying to find which wire is the one I connect the reverse trigger to . I found these wired by my foot well not sure if it's even the right ones though.
Sent from my Moto G (4) using Tapatalk
perro547 is offline   Reply With Quote
Old 09-15-2021, 12:14 PM   #2
phpist
Drives: Yaris III
hello,
have you solved this? Was this connector for rear camera?
phpist is offline   Reply With Quote
Old 09-15-2021, 01:35 PM   #3
colinpilla
Drives: 2018 yaris
2018 Toyota yaris Thailand spec
Hi Guys i have 2018 Toyota yaris Thailand spec, i am having troubles installing my rear camera there isn't any RCA ports on the radio. what do i do.
colinpilla is offline   Reply With Quote
Old 09-15-2021, 06:29 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Originally Posted by phpist View Post
hello,
From memory, when I installed my rear view camera, that connector is for the central locking. Some versions of the hatchbacks in some countries have a key operated lock in the hatch. This connector then signals the doors to unlock or lock when the hatch key lock is operated.
I wasn't able to find any wiring in the hatch for a rear view camera, and ended up running a video cable all the way back to the radio. I tapped 12 volts from a reversing light to power the camera and provide a switching signal to the radio.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Rear view camera William's Yaris Third Gen Yaris General Discussion 2 08-26-2017 10:48 AM
