07-28-2006, 07:50 PM | #1 |
Drives: 2007 Yaris S Sedan Join Date: Jul 2006
More Companies with Mods
I just got the car back from progress. They are going to be making a rear sway bar and springs for us. Release date of about 4 weeks for the bar, and about 6 weeks for the springs. Not decided yet, but they are thinking a 1.8" even drop, with qutie a bit higher spring rates then stock. On a side note, The sedan was even with the liftback with front weight, but the sedan was 40 lbs lighter in the rear. Kinda odd I thought.... I will keep you guys updated...
07-28-2006, 08:34 PM | #2 |
Do the sedans come with a rear sway at all?
Will they be making a rear sway for the Liftbacks (we dont have one.. period!)? |
07-29-2006, 07:38 AM | #3 | |
Drives: 2007 Liftback Join Date: Jul 2006
2007 Liftback Blazing Blue Cold Weather, Convenience Package, Arm Rest, Floor mats, Weathertech vent visors |
07-30-2006, 01:23 PM | #4 |
The sedan is 40 lbs lighter then the liftback... And the sway bar will fit the sedan and the liftback. The cars share the same suspension....
07-30-2006, 06:04 PM | #5 |
I dont understand how that could be..
But you are correct! Curb Weight Liftback = 2,290 lbs. Sedan = 2,288 lbs. |
07-30-2006, 07:26 PM | #6 |
It doesn't make sense to me either. I guess our rear hatch just weighs a ton...
07-30-2006, 07:52 PM | #7 |
Pretty odd for sure. The same width, a little shorter ( the Sedan), but way longer. All I can think of is the glass.
07-30-2006, 10:48 PM | #8 |
www.OZTOYOTA.com
Drives: Toyota Echo Join Date: Feb 2006
Liftback = probably a stronger / more metal chassis ... = more weight.
Also, the rear slidey seat assembly weighs heaps in comparison to the sedans which is static.
www.oztoyota.com - Australian Toyota ECHO and YARIS Club |
07-31-2006, 12:47 AM | #9 | |
Yarii Hunter
Drives: 2007 Yaris Liftback and S13's Join Date: May 2006
Thanks for all the help over the years, YarisWorld!!! |
07-31-2006, 12:53 AM | #10 | |
Drives: 2007 Yaris S Join Date: May 2006
read some where that the sedan is about 2 inches narrower, 2 inches shorter(less tall..), and 2 inches longer |
07-31-2006, 10:07 AM | #11 | |
07-31-2006, 03:09 PM | #12 |
Drives: Silver Hatchback Join Date: Jul 2006
msn autos says its .2 inches skinnier
08-01-2006, 01:32 AM | #13 |
i knew it was 2 something or other ;)
08-01-2006, 05:13 PM | #14 |
Resident Redneck
Drives: 07 Polar White Yaris Sedan 5M Join Date: Jul 2006
I wouldn't be too surprised about the weights- hatchbacks are usually heavier than their sedan counterparts (the Acura Integra 4 door sedan is lighter and stiffer than the hatchback, the 96-00 Civic sedans are lighter than the hatchbacks and coupes, and so on). Sp33dy and FlintS are both right- glass and hatchback doors weigh a ton, and there is extra bracing to make up for the smaller/more compact pillars.
My other rides: 2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon! 1999 Honda Civic EX Coupe 5M w/ B18 powaa 1985 Toyota Celica GTS Coupe 5M- track whip http://www.importlounge.com |
08-01-2006, 06:35 PM | #15 |
ya hence the HUGE C Pillars
Similar Threads | ||||
Engine mods - why bother? | RallyYaris | Performance Modifications | 143 | 12-24-2006 03:56 AM |
oil companies profitting... | hhcchen | Off-topic / Other Cars / Everything else Discussions | 22 | 08-08-2006 08:44 PM |
Mod's List | riceboy | General Yaris / Vitz Discussion | 43 | 07-25-2006 09:49 PM |
Dealer MOD's | silverRS | General Yaris / Vitz Discussion | 8 | 05-08-2006 04:18 PM |
