Old 04-12-2013, 12:40 PM   #1
coffiend
coffiend's Avatar
Drives: 08 Black LB
Suspension Problems
So, my car has almost reached 100k and I'm finally starting to see some issues with it, its been perfect up to this point.
The other day, I noticed while turning my suspension was making a creeking / popping noise. It continued doing this for about a day and a half then somewhat went away.
Today driving from lunch, my steering wheel starting shaking back and and forth steadily, not a lot of small vibration, just consistently turning back and forth while driving pretty slow (about 20 MPH)
I plan on going and getting it checked out, just wanted to see if anyone here had some insight as to what it might be.
Thanks!
Old 04-12-2013, 12:54 PM   #2
YarisSedan
YarisSedan's Avatar
Drives: 08 Yaris Sedan
Send a message via AIM to YarisSedan
I noticed your car is lowered my guess would be a strut mount/bearing that could cause the creaking popping however it wouldn't really cause a steering wheel vibration at low speeds. It could be a worn out tie rod end usually they go bad in slow progression though they arent just good one day and totally worn the next day. Either way i would get it check out by a shop soon as possible because its most likely going to get worse and could potential be a safety issue.
Old 04-12-2013, 03:00 PM   #3
The creaking/popping could also be the broken control arm bolt issue:
http://www.yarisworld.com/forums/showthread.php?t=27658
Old 04-12-2013, 09:01 PM   #4
muffin_top
Drives: 2012 Yaris SE 5MT
I'm betting this is the cause. It usually manifests itself as a violent side to side shake of the steering wheel.
Get it to a dealer asap!!
muffin_top is offline   Reply With Quote
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Question about VITZ RS suspension and Yaris / Vitz (Non-RS) seechoong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-04-2013 02:47 AM
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
NSW Proposed Suspension Restrictions Bella Australia 0 09-22-2010 01:51 AM
Tein Basic Compact Suspension for SALE!! 33lam Australia 14 04-17-2010 08:24 PM
