Old 12-08-2008, 08:01 PM   #19
sidewinder
"Gettin Jiggy wit it"
sidewinder's Avatar
Drives: 09 Yaris " S " Hatchback
long running of engine
Do not worry about damaging your engine, with it idleing for 1.5 hours in temps that low. The worse thing that you probably did was build up a little bit of carbon deposits. If you ran the car every day idling that long you could clog your cat converter.Take it out on the highway and clean it out a little bit.
I have worked on engines all my life, every thing from car engines, diesels, to jet engines and as long as your cooling system works properly you won't hurt the car. With the extra cold weather we get in New England, you need to properly warm your car up. Today was 5 degrees out and I warmed mine for about 5 minutes before driving off. Good luck with your car and put your mind to rest.
sidewinder is offline   Reply With Quote
Old 12-08-2008, 08:26 PM   #20
iwantayarisnyc
Drives: 08 sedan auto
thanks friend
iwantayarisnyc is offline   Reply With Quote
Old 12-08-2008, 10:00 PM   #21
DMart
same amount of posts lol
DMart's Avatar
Drives: 07 Meteorite Metallic LB
i left mine on for about 3 hours while i was in class...i was up studying all night and had a test so i wasnt completely there, left it running with the a/c on in the parking lot, on the way back to my car i thought i lost my keys, i get there and the car was running...i felt so dumb...lol
DMart is offline   Reply With Quote
Old 12-08-2008, 10:03 PM   #22
Originally Posted by lita_g View Post
And that's why I never leave the car running and close the door behind, unless I crack open a window. Call me paranoid but I would freak out if I got locked out of my car.
I do the same thing even when I'm getting gas. I'll take the keys out but still crack open a window...you never know what can happen, right?
Old 12-09-2008, 01:09 AM   #23
gid
Drives: '08 Yaris sedan , '08 Liftback
agree ...
Originally Posted by iwantayarisnyc View Post
well you got the wind blowing through the car.......it relatively cools it down....now if you spent most of that time in traffic....that would be bad
the car idling for that long period of time is not beneficial . I highly suggest that you get your oil changed soon as possible . Long idling can lead to fuel dilution , which can thin the oil , thus leading to premature wear . GOOD LUCK
gid is offline   Reply With Quote
Old 12-09-2008, 01:18 AM   #24
gid
if you leave a car running for long period of time it can lead to valvetrain damage , rings , or other due to the extreme heat . That's why you have a cooling fan , which is no substitute for air passing through the radiator at faster speeds . An acquantance left his new MUSTANG running all night in the garage and noticed smoke would come out of tailpipe when started after the mishap , most likely from overheating the valves or piston rings or both . He decided to trade it in for a new COROLLA . Figured let someone else deal with what may occur further down the road .
Old 12-09-2008, 01:23 AM   #25
gid
another thing that could be damaged is the catalytic converter(s) or other parts of the emission system that would lead to poor performance , such as rough idle ,etc..
Old 12-09-2008, 02:04 AM   #26
Revsson
I never expected that from a fellow MM owner!!!
Glad no one messed with it. That's got to be a weird feeling thinking
you lost the keys.
Old 12-09-2008, 02:48 AM   #27
luckypierre
I would not sweat it. The Yaris engine is bulletproof. 1.5 hours is nothing. Now if you left it idling for days until an dentire gas tank ran out, that might be one thing, but this engine is built for survival.
luckypierre is offline   Reply With Quote
Old 12-09-2008, 03:58 AM   #28
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i idle here and there when i want heat working on audio in the car... no issues here
Old 12-09-2008, 05:26 AM   #29
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
You guys are amazingly anal about the car. Heat may build up at idle but its winter over there. Its probably less stressful on the engine to be at 0mph and idling at 600rpm for two hours than to be sitting on 70mph and 3500rpm. Remember, the engine still has a thermal fan that turns on when water temps get too high. It takes care of itself; you only need to keep it fed with fuel and serviced regularly.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 12-09-2008, 11:45 AM   #30
imperial4ever
Drives: 2008 Hyundai Accent SE
i just got locked out today, thanks to the aftermarket alarm.
1 hour 30 minutes, the engine was running in 35 F weather, with wind chill making it feel 28F
not gooooood..............engine feels different now.....
Probably overheated and burned out your cataylitic converter.
imperial4ever is offline   Reply With Quote
Old 12-09-2008, 12:22 PM   #31
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I've ran my car has ran for 5 hrs at a time.... but when driving a constant 70mph....
I don't understand how idling for 1/3 the time can be any where near the wear & tear that driving highway speeds is.
It is all in your head.
Old 12-09-2008, 12:24 PM   #32
iwantayarisnyc
thanks bro
Old 12-09-2008, 01:21 PM   #33
gid
when you drive at highway speeds the water pump circulates the coolant throughout the engine block faster that then passes into the radiator which cools the coolant that then recylces picking up the heat caused by friction within your engine . The wind that passes around your engine helps cool as well . When idling , this is not possibly ( relies on the fan ) . This is why it's mentioned in owners manual to change oil sooner if stop and go driving or when towing , called SEVERE CONDITIONS . Beileve me I've learned by experience . Heavily relied on cars for our income . CHANGE THE OIL SOON AS POSSIBLE .
Old 12-09-2008, 03:02 PM   #34
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Don't waste your money, you DON'T need an oil change...
Old 12-09-2008, 03:33 PM   #35
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
About 5 hours on a trip to Tennessee
Old 12-17-2008, 10:07 AM   #36
Masteraal
Masteraal's Avatar
Drives: Black Yaris YRS 3dr Manual
Fifth gear showed on one of their eps the testing a ford focus ST goes through. It was 100000miles at full throttle (6000rpm)
i think 1.5hrs idling is not going to kill the yaris hehe
Masteraal is offline   Reply With Quote
retrofit time as soon as I get my yaris birdy General Yaris / Vitz Discussion 15 05-02-2006 05:46 PM
engine modify Yaris D-4D uraz Performance Modifications 10 04-30-2006 11:53 AM
