07-20-2018, 02:26 PM | #1 |
Drives: Toyota Yaris SEdan Join Date: Oct 2016
ECU Swap
I've recently swapped my 2nzfe to 1nzfe.....but the ECU is still the 2nzfe's....i didn't have the time to sort out the wiring of the car.......so far the car is running good....except the car is idling rough, i wanna knw if the ECU can be swapped without any wiring work, like if its a plug and play thing.....though i have the U440 transmission......1nzfe's have the U340 transmission.......need expert opinion
12-19-2020, 03:12 PM | #2 |
Drives: Toyota Yaris 2000 Join Date: Dec 2020
Hola tengo exactamente la misma pregunta, alguno tiene informacion sobre si es plug and play?
Similar Threads | ||||
Yaris Motor Swap Thread *Read before posting swap threads* | Sabretooth | Performance Modifications | 218 | 02-19-2024 09:04 PM |
T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
2zz Swap on Vitz/Yaris SCP90 | blindmanwatching | Performance Modifications | 34 | 05-17-2015 10:50 AM |
