10-31-2016, 10:45 AM | #19 |
Drives: Yaris 1.3 2012 Join Date: Jul 2016
can we find this on ebay? it is hard to find it here in greece in a logic price!
Thanks |
02-26-2018, 03:26 AM | #20 |
Drives: Toyota Yaris Hybrid 1.5 2018 Join Date: May 2015
Thanks for this its amazing :D when you buy the part is it 2 of the same?. do you buy 2x "81080-0d010" or is the H,L at part of it ? 81080H and 81080L are the diffrent ?
Thanks Tim |
02-28-2018, 06:48 PM | #21 |
Drives: 2012 Yaris TR 1.33 VVT-i Man Join Date: Nov 2014
09-19-2018, 07:43 PM | #22 |
Drives: Yaris 2012 1.0 5 doors Join Date: Feb 2012
Hello
I just check on my Yaris to buy and install the lights And i wondering discover on Passager side (here is the photo) https://lh3.googleusercontent.com/ns...=w1600-h778-no I think have missing part or is normal on cheap 1.0l model that? My car is yaris 5 doors hatchback 2012 with 1.0 european version spain KSP90L-CHMRKW Thanks Nicolas |
09-21-2018, 11:22 AM | #23 |
yeah toyota offers a light appearance package on one of their websites. 4
https://trdparts4u.toyotaofdallas.co...product=329856 |
09-24-2018, 08:18 AM | #24 |
Drives: Yaris YR 2013 Join Date: Jan 2017
I still can't find the "spare" connectors on neither sides... I've an Australian 2013 Gen3 Yaris albeit the YR spec (lowest). On the driver side I've taken out the small panel (two screws) beneath the knee airbag and looked under, no spare connector. On the passenger side, I've looked around and behind all the existing wires and connectors and didn't find any. Can someone that has that connector take a picture of the actual connector and location of it?
I really don't want to run a wire from the fuse box nor running a wire all the way from the existing dome light down the footwell... :) thanks a lot ppl! |
10-06-2018, 03:27 AM | #25 | |
Drives: Starlet Join Date: Nov 2017
If you really wanted to do it, you'd probably find the necessary wiring on one of the connectors that sit behind the kick panels. You'd need to get testing with a multimeter to see if you can find the ground wire that's being switched and a power source. Good luck :) |
10-06-2018, 09:17 PM | #26 | |
11-10-2018, 07:40 AM | #27 |
Finally got it done!!
Okay, finally done the wiring. End product looks like this.
1. Remove the front map reading light assembly. Solder a connector to these two locations. Of course use your multimeter or a simple lightbulb to test polarity. 2. Run wire from the assembly recess through to windshield, then under the roof lining and across to each A-pillar. Going around the airbag (do not obstruct) and through to under rubber seal. Run along and above the seal through to B-pillar. 3. Rear door rubber seal, you'd need to slit two holes to fit the flexible LED strip light through. Something like this should suffice (the one I bought earlier no longer exist). https://www.ebay.com.au/itm/Waterpro...YAAOSweNZa8V~u Now my rear lights fade out just like the map light. (animated GIF) https://imgur.com/jHOHeAA/ Since the hard part of wiring is done, I can now easily do the footwell light. |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 07:21 AM |
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris | omendt | Items for Sale by private party | 0 | 07-13-2010 09:46 AM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
Help: Water/Moisture Entered Fog Light Assembly | bigsky2 | DIY / Maintenance / Service | 10 | 12-19-2006 12:10 AM |
