Old 05-14-2012, 02:03 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
4 or 5-channel amp. w/ auxiliary audio input?
Anyone know of a decent 4 or 5-channel amplifier that also has a built in auxiliary audio input?
I will be getting a Pioneer AppRadio 2 and the only input it has is the USB connection for the iPod/iPhone/Android device. My Yaris has the 3.5mm audio jack built in near the parking brake lever and I'd like to be able to use that still when I get the AppRadio 2.
Heatware:
http://www.heatware.com/eval.php?id=35947
Old 05-14-2012, 02:15 PM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
What do you connect to the 3.5 ?
Old 05-14-2012, 02:18 PM   #3
IsLNdbOi
IsLNdbOi's Avatar
The 3.5mm audio jack is the stock one that comes with many Yarii (located near the parking brake lever). You connect anything with a 3.5mm output / headphone jack to that.
Heatware:
Old 05-14-2012, 02:23 PM   #4
_S7V7N_
_S7V7N_'s Avatar
I'm askin what do you connect to it specifically ? Since the majority of electronics now come with Blue Tooth
Old 05-14-2012, 02:25 PM   #5
IsLNdbOi
IsLNdbOi's Avatar
I don't connect anything to it specifically. I want to retain use of that OEM 3.5mm input because I have passengers all the time that have audio devices with them that won't work with the AppRadio 2's USB interface, but will work just fine plugged into a 3.5mm input.
The AppRadio 2's bluetooth is only for phone functions. It doesn't have A2DP or AVRCP bluetooth profiles.
So do you know of any 4 or 5-channel amplifiers with aux inputs?
Heatware:
Old 05-14-2012, 02:30 PM   #6
_S7V7N_
_S7V7N_'s Avatar
Amps no equalizers yes. Let me do a google search for what you're lookin for but I've never seen any.
Ps : exact model number of unit
Old 05-14-2012, 03:01 PM   #7
IsLNdbOi
IsLNdbOi's Avatar
Bluetooth isn't an issue. As I've mentioned, the AppRadio does not have the A2DP bluetooth profile which is required for bluetooth audio streaming.
Heatware:
Old 05-14-2012, 03:18 PM   #8
_S7V7N_
_S7V7N_'s Avatar
And I'm asking for a Model number so I can do a full search on a harness that will give you another aux input. Or more options. Wiring that 3.5 directly into an amp will bypass the app radio and its equalizer.
If you wanted to do that you'd just get a 3.5 to rca splitter and go into the input of your amp. It'll sound like crap.
Or just maybe your radio has RcA inputs then bam problem solved.
Ps I know it has RCA outputs. Need 1 input
Old 05-14-2012, 03:36 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
Pioneer AppRadio 2
SPH-DA100
Heatware:
Old 05-28-2012, 06:24 PM   #10
razingman
Drives: 2007 ls liftback 5 door manual
Get the JVC KW900bt, I got it and love it
razingman is offline   Reply With Quote
Old 05-28-2012, 06:40 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
Didn't get the AppRadio 2. Went ahead and got the Pioneer AVH-P8400BH instead along with an Alpine KTP-445U 4-channel micro-amp..
Very happy with it so far. Now I just need to upgrade my speakers.
Heatware:
FS/FT: Eclipse 3650 4 + 1 channel amp yaris2010RS Items for Sale by private party 3 03-11-2011 11:24 AM
Issue for LP setting on 4 channel amp. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 02-08-2010 12:10 PM
bridging 4 channel amp o2cavyss In Car Entertainment + Electronics (audio / video / alarm) 20 01-21-2010 03:40 PM
My new deck and amp install plus question about fine tuning 4 channel amp.... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 07-03-2009 12:37 PM
