Old 06-17-2019, 12:28 PM   #1
h-dogg
Drives: 2015 Yaris L
Minor Annoyance: Driver Door Panel Switch Cover
Hi,
Not sure if this is just me or occurs in other 2015 Yaris. The driver door panel switch cover is very creaky. Whenever I close the door from the inside by pulling the handle the plastic is very creaky there.
I wonder if this is common?
Also, when the fan is on, it makes a bit of a high-pitch sound. Is this normal?
Thanks!
h-dogg is offline   Reply With Quote
Old 06-17-2019, 04:14 PM   #2
scylla
I have same year, same model and I have neither of those problems. You can take the door panel off and see if you have a loose screw or mounting clip.
The whining fan would seem to be a bigger concern. Mine is super quiet. Open your glove box and make sure the fan is mounted securely and the blades don't wobble.
scylla is offline   Reply With Quote
Old 06-18-2019, 01:10 AM   #3
h-dogg
Thanks, will check on it this weekend!
Old 06-19-2019, 01:16 PM   #4
matti
Drives: 2017 Yaris L (5sp manual)
Originally Posted by h-dogg View Post
Hi,
Thanks!
Hi there. I had a 2012 Yaris and now have a 2017 and both doors creak/ed as you describe.
matti is offline   Reply With Quote
Old 06-20-2019, 10:47 PM   #5
h-dogg
Thanks for letting me know that I am not the only one that has a creaky door handle. I did pop off the plastic panel and tightened the screws around. I still have the same creak..haha..oh well
Old 06-21-2019, 11:57 AM   #6
matti
My two Yaris are definitely some of the creakiest cars I've owned!
Old 06-30-2019, 03:44 PM   #7
2008RedHatch
2008RedHatch's Avatar
Drives: 2018 Yaris LE liftback, 2020
I got the recall done for the front door wiring harness, and seems like the squeaking went away. My 2016
2008RedHatch is offline   Reply With Quote
Old 06-30-2019, 10:40 PM   #8
h-dogg
that's good to know..just waiting for my recall letter and hopefully that will fix the issue.
Old 07-01-2019, 12:55 AM   #9
2008RedHatch
Maybe saw something loose and fixed it?
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
WTB: Driver side view mirror cover black06spec-v Willing to Buy by private party 1 09-16-2014 12:38 AM
LB Driver Side Mirror Cover (Backplate) posaunemeister Willing to Buy by private party 2 10-17-2011 12:06 AM
TRD gauge cover for the driver glovebox MicroHB Willing to Buy by private party 1 02-14-2009 12:37 PM
