Old 04-15-2013, 03:16 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Is there a way to "enable" daytime running lights?
I have a 2009 Yaris LB and noticed when sitting in front of a shop window that it does not have DTR's. Is this a setting somewhere that I can "turn on" or is it something that has to be installed from the factory?
Old 04-15-2013, 03:34 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2018 Volkswagen GTI
You could just turn your lights one when you start the car...
Otherwise, I'm 99.99% that, except for the new model, no Yaris hatchback came with DRL.
Old 04-15-2013, 03:40 PM   #3
DRLs were standard equipment for 2008 and 2009, so the prior owner may have disabled yours. If you want to know for sure if it was built with them, shoot me your VIN, or take a look under the dash above and to the right of the steering column for the DRL module.
Old 04-15-2013, 04:29 PM   #4
Shinare
Shinare's Avatar
I don't have it with me, but I sent it to you last week I think. (if you still have it)
Old 04-15-2013, 05:18 PM   #5
MadMax
MadMax's Avatar
Wait, what? My 2008 didn't come with DRLs, and I am the original owner...
Old 04-15-2013, 05:19 PM   #6
Shinare
Shinare's Avatar
I found it in my PM history and PM'ed it to ya again in case you deleted it. :) Thanks!
Old 04-15-2013, 05:25 PM   #7
I forgot about having looked up the keyless entry piece for you...
It turns out your car does not have the DRLs. For 2009 it was part of the cold are spec, and yours was not built with that package.
There is a different under dash harness for ones with and without it, so unfortunately adding them is not as easy as plugging the module in. The easiest way to add a set would be to use one of the Phillips DRL kits.
Old 04-15-2013, 05:37 PM   #8
Shinare
Shinare's Avatar
Thanks for your efforts Scott, its not that important, just something I thought was odd that wasn't "working" and would be nice if there was a free way of getting them to work. heh
Old 04-15-2013, 05:45 PM   #9
It looks like for 2008, like 2009, they were only standard on cold area spec. Yaris.
Old 04-15-2013, 09:23 PM   #10
MadMax
MadMax's Avatar
Thanks, I thought there was some distinguishing difference. Whereas I always drive with my lights on, I still prefer the option of being able to turn them off myself if so desired.
Old 04-22-2013, 04:36 AM   #11
nookandcrannycar
and included in the All Weather Package option ($110.00) on my 2007 cold area spec Yaris (shipped to CT and purchased in RI).
Old 04-23-2013, 03:27 AM   #12
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
If you dont have DRL and you want them just turning your lights on would be the logical plan-B.
Have Yaris will travel..
Old 04-23-2013, 08:47 AM   #13
esse10
Drives: 2009 yaris 2 door
drl
just turn the little knob U self. You really don't want those on all the time because they end up ruining the headlight outer lens , they turn light brown and foggy looking, then in a few years you have to replace the whole headlight. Most parts place dont' sell you just the outer lens because they make more money that way..LOL of course.
Old 04-26-2013, 03:44 AM   #14
jambo101
jambo101's Avatar
I always thought the misting up of the plastic headlight lens was due to age,road rash and ultraviolet damage from the sun.You are saying its because of the headlight being on all the time?
Old 04-26-2013, 08:57 PM   #15
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
No. The headlights being on has nothing to do with it. The plastic just ages and oxidizes, causing it to turn cloudy and yellow.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 01-27-2019, 06:59 AM   #16
cylaptor
Drives: Yaris 1.3 VVTi R&B
Is it permitted to have a parking light + front fog lamp instead of Drl?
cylaptor is offline   Reply With Quote
Old 01-27-2019, 03:01 PM   #17
IllusionX
Drives: 07 Yaris Sedan Aero
I don't know if DRL is required in your country, but you might want to check with local authorities see what lights can be on at any time.
I know some countries prohibits fog lights when there is no fog.
In my country, DRL is what was designed by the manufacturer, and shall not be modified.
Old 01-27-2019, 04:25 PM   #18
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
I Think it is Here in EU,
Many newer VW use Fog lights as DRL.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
- DISABLED DayTime Running Lights How To- 2007 Yaris! - Chris07LB DIY / Maintenance / Service 266 09-04-2017 03:34 AM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch powermicro In Car Entertainment + Electronics (audio / video / alarm) 1 05-14-2009 12:12 AM
Does the Yaris come with............. Driver Cosmetic Modifications (Exterior/Interior) 7 08-21-2006 12:06 AM
