Old 01-07-2018, 06:06 PM   #1
SirDigby
Drives: 2007 yaris 3 door
lower rod ratio
has anyone ever lowered compression by lowering rod ratio? i was noticing the long stroke the 1nz has, and if i lowered the stroke and increased the piston width, i was thinking it would move the torque curve out 500-1000 and add 1000-2000 on the top end, (maybe more) where the turbocharger is producing higher boost.
i have not done any research into what rod lengths are available/ commonly used, it was just a thought i had all day yesterday.
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 03:23 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
Yaris wheel rate ratio (06+) ? dsc_pat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 07-05-2007 05:43 PM
