Old 04-06-2013, 12:26 PM   #1
vinny121
Drives: 2007 Yaris Sedan
Unhappy Climate control bulb
Hi, Do you know how to take apart the climate control knob and replace the bulb? I not sure which clip to remove and the Toyota service manual appears to be no help. I was thinking of purchasing the entire A/C panel assembly with the bulbs to make this easier but I am not sure. I have 2 bulbs out on my A/C panel upper right (outer ring) and the lower knob (outer ring). Pictures are attached. Thanks! I have the Sedan with 105K miles.
vinny121 is offline   Reply With Quote
Old 04-06-2013, 06:30 PM   #2
The bulb is mounted to the rear of the knob. You will see a small round area with a flat indentation in the middle. You simply turn it a quarter of a turn with a flat blade screwdriver to release it.
Old 04-06-2013, 08:56 PM   #3
bcat37645
Drives: 2dr Hatchback
My bulb appears to be out on my climate control knob (the temperature knob with the blue/red zones), too. The other two knobs light up perfectly, and everything is working fine, so I don't think it's a fuse. Is the correct replacement bulb part number 9001001113? I have a 2009 Yaris. Thanks!
bcat37645 is offline   Reply With Quote
Old 04-06-2013, 09:33 PM   #4
That is the correct part number.
The recessed area in the center is where the bulb is located. 1/4 turn with a flat head screwdriver releases it.
And, this is what the bulb assembly looks like when removed:
Old 04-06-2013, 09:39 PM   #5
bcat37645
CTScott, thank you. I suppose it's not accessible by simply pulling the knob off...??? I bet the entire panel must come off...!!!
Old 04-06-2013, 09:44 PM   #6
Correct. The bulb is on the rear and to access it you must remove the entire control panel. That requires removing the vertical pieces along side of the radio (by simply getting your fingers behind and pulling), removing the radio trim (again just pulling), and then pulling the AC control panel off.
Old 04-06-2013, 09:46 PM   #7
bcat37645
Last question. No screws to remove first? Just start by pulling panels? Thank you.
Old 04-06-2013, 09:47 PM   #8
Correct.
Old 04-06-2013, 09:49 PM   #9
bcat37645
Got it...thanks a lot.
Old 04-07-2013, 08:34 AM   #10
vinny121
Thanks all for your help. For the sedan, I had to remove the 4 black screws around the radio to get access to the AC control panel. Thanks for the pics of where the bulb is located. For the climate control knob, it is not obvious which clips to separate to get access to the bulb. Any ideas? This may help:
Old 04-07-2013, 09:26 AM   #11
Yes - The sedan with the integrated radio does require removing screws to get the radio face (or in that case the entire radio) loose.
For the knobs, you just need to release the cable assembly from the back of the knob. You really don't need to remove the entire knob from the panel. People often break the little mounting tabs when doing so, as there are four tabs on the knob assembly that click into four slots on the panel, and the panel is very brittle, so it is easy to break the slots.
Old 01-24-2014, 08:22 AM   #12
stevens_uk
stevens_uk's Avatar
Drives: Yaris Sport 2014
Attachment 50387
Attachment 50388
thanks, this post has helped me loads, can I ask, this green bulb.. can it be replaced with different colours? as I have replaced the head unit, its lights are orange/red and the climate control are green, I'm hoping to match them up.
stevens_uk is offline   Reply With Quote
Old 01-24-2014, 10:14 AM   #13
The green is just a sleeve on the bulb. I am not sure if you can find the bulb with other color sleeves, but you may be able to find replacement LED bulbs of that same mounting.
Old 01-24-2014, 10:50 AM   #14
IllusionX
Drives: 07 Yaris Sedan Aero
is it a T3 or a T4.7 that go in there?
Old 01-24-2014, 11:09 AM   #15
Actually T4 (AKA Neo-wedge Type B).
Here is the thread I mentioned above:
http://www.yarisworld.com/forums/showthread.php?t=9857
Old 01-25-2014, 01:25 AM   #16
lamadoo
Drives: 2007 Yaris 3door white
CTScott is a legend around here, yaris guru
lamadoo is offline   Reply With Quote
Old 01-04-2015, 04:53 PM   #17
LSandulak
LSandulak's Avatar
Drives: 2008 Toyota Yaris
Thanks CTScott. Really appreciate your effects.
LSandulak is offline   Reply With Quote
Old 01-30-2015, 07:26 AM   #18
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
and yet another person to say thanks. that link you supplied for changing them out is diamond.
El Kapitan is offline   Reply With Quote
Tags
climate bulb replace
The electronic climate control displays mrbond In Car Entertainment + Electronics (audio / video / alarm) 43 04-18-2021 03:34 AM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
Yaris 09 climate control lights alt_k1ll3r DIY / Maintenance / Service 2 11-11-2008 10:19 PM
Bulbs For Behind The 3 Climate Control Knobs razzorjet2 DIY / Maintenance / Service 2 04-06-2007 10:41 AM
