Old 10-14-2019, 11:21 PM   #1
yarisbug
yarisbug's Avatar
Drives: 2010 1.4 d4d
What 15" steel wheels fit 2018 Yaris Hatchback?
I've got 16" aluminum factory wheels on my 2019 Yaris Hatch/Liftback. I'm in Canada so it's the old style made-by-Toyota in France version.
Anywho I think I should really buy 15" steel wheels and put some winter tires on there.
Do Corolla, Prius, or what stock steel wheels fit? I plan on trying to find something near me using http://www.car-part.com
My first choice would be an aluminum wheel but I think for cost purposes I'll probably go with steel and some OEM looking wheel covers.
yarisbug is offline   Reply With Quote
Old 10-15-2019, 05:42 PM   #2
h-dogg
Drives: 2015 Yaris L
Probably 4x100, like prius c wheels. I think the new corollas are 5 lugs now.
h-dogg is offline   Reply With Quote
Old 12-10-2019, 07:34 PM   #3
xxcanuckxx
Drives: 2015 SE HB
If you are going on the cheap, just search the local wheel shops or an auto recycling place, cookstown or carcone's
xxcanuckxx is offline   Reply With Quote
Old 12-10-2019, 08:04 PM   #4
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
I would advise against aluminum rims for winter. They usually oxidize and get that white flaky stuff. A known source for many leaks. However rusy rims could cause you the same issues. Cost wise steel is always cheaper though.
As for rim size, I would think a 15" rim would be easier to find tires for these days. I dont think any cars come with 14" rims anymore. 15" is way more popular. As for what fits... basically any toyota or honda 4 bolt rim. 4x100 is the stud spacing and the center bore is 54mm. Basically the smallest center bore available. Just about any 4x100 should fit.
If you're looking for a frugal setup, look on kijiji. Theres thousands of used winters already on rims available. From one season left to basically brand new. I've run many kijiji rims/tires over the years without issue.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 12-10-2019, 09:02 PM   #5
yarisbug
yarisbug's Avatar
OK well I should update. The 15" steelies from the LE Yaris do fit over the SE Yaris brakes. They fit fine, I bought new OEM wheels from the dealer.
2009-2011 Yaris OEM 15" Alloy Wheels on 2012-2014 Yaris L 3/5-Door Hatchback? Kalispel Third Gen Yaris General Discussion 4 07-09-2014 12:47 AM
will 2010 Yaris wheels fit 2012 Yaris? yaris8888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-24-2012 11:36 PM
WTB: 4 Stock 15" Steel Wheels (with or without tires) kapo Items for Sale by private party 5 04-01-2011 05:35 PM
