Old 12-02-2014, 06:48 PM   #1
kelcarII
Drives: Yarus
Injector Replacement
I'm looking for advice on injector replacement, not cleaning and reusing.
I found remanufactured ones for as cheap a $40 each.
New as high as $188 each. I really don't have the time to dick around so it's a replacement and back to work deal. So I seek the answers from the knowledgeable on the following questions:
1. new or remanufactured?
2. brand?
3. is there an o ring kit available?
4. what other parts will I need to do the job
Trying BG 44 first.
Thanks,
Mark
kelcarII is offline   Reply With Quote
Old 12-02-2014, 07:58 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Why do you feel you need to replace your injectors?
Old 12-03-2014, 08:15 AM   #3
kelcarII
Drives: Yarus
did the screwdriver stethoscope method and one intermittently is fairly noisy. If I'm there doing one, I would rather replace all 4
Old 12-03-2014, 08:28 AM   #4
Bluevitz-rs
And that noisy injector is causing what code and or symptoms?
Sent from my iPod Touch
Old 12-03-2014, 11:35 AM   #5
bronsin
bronsin's Avatar
How many miles/what year?
Thanks!
Old 12-03-2014, 02:43 PM   #6
tmontague
tmontague's Avatar
I wan't aware that the injectors should be replaced unless it's throwing a CEL or is damaged. The FI's are notorious for being loud on the Yaris. I can't comment if the re-manufactured ones are just as good as brand new, but for the price I wouldn't replace all of them unless they are all bad. They aren't something that tends to go bad on the Yaris from what I've heard.
Old 12-03-2014, 05:53 PM   #7
If you really want to replace the set, I have a set on hand that had low miles, plus I bench cleaned and tested them. I could sell them to you for a whole lot less than even the remanfactured set.
Old 11-03-2019, 09:04 PM   #8
"G"
Drives: 2007 Yaris Hatch
If you really want to replace the set, I have a set on hand that had low miles, plus I bench cleaned and tested them. I could sell them to you for a whole lot less than even the remanufactured set.
Interested, pm me.
"G" is offline   Reply With Quote
Old 11-12-2019, 09:57 AM   #9
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by "G" View Post
Interested, pm me.
That post is almost 5 years old. He's no longer an active member on the forums.
Deatschwerks Fuel Injector Service Review fnkngrv Forced Induction Forum 7 03-14-2014 12:15 PM
Fuel Injector Bench Cleaning and Testing CTScott DIY / Maintenance / Service 2 05-31-2013 10:20 PM
Gumout fuel injector cleaner Sabretooth DIY / Maintenance / Service 10 04-10-2009 10:33 PM
Tacoma 7th injector.. Multiple questions...... nbays1 Off-topic / Other Cars / Everything else Discussions 0 03-23-2009 01:47 AM
