Old 06-25-2007, 08:40 AM   #1
Airknight
Drives: Toyota Vitz
Vitz (1st Gen) Tid Bits
I have been able to decipher a few things from the Vitz (First Generation 1999-2005) Owner's Manual (Japanese language) that may be of interest to some:
1) O/D OFF button on the automatic gear shift lever is used to deactivate the 4th gear and, only the first three gears are functional ('O/D OFF' legend is lit on the instrument panel). This 3-gear configuration is power-efficient during a descent down an incline or, when trying to overtake another vehicle. With the O/D engaged, all four gears are in action again.
2) The fuel tank capacity of the FF-engined Vitz (1.0l & 1.3l) is 40 liters.
3) The tyre pressure for the 155/80R & 175/65R FF-engined Vitz is 2.2 kg/cm2 or 31 psi.
Airknight is offline   Reply With Quote
Old 03-09-2017, 04:24 AM   #2
murtaza319
Drives: Toyota Yaris
hi can you tell how to read fault code in yaris 2000 1sz-fe
murtaza319 is offline   Reply With Quote
Vitz (1st Gen) Tid Bits Airknight DIY / Maintenance / Service 0 06-25-2007 05:12 AM
