Old 01-10-2009, 11:19 PM   #1
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
Adjusting Windshield Washer Jets
I was curious, I notice on my Yaris when I am at driving speed and turn the washer jets on to spray washer fluid on my window, it only reaches the very lower portion of the windshield, if Im stopped will it reach the higher portion of the windows, I would like to know is there a way to aim it a little higher cause as driving speed i have to reply on the wiper to get the fluid to the part of the window I visually look out at. I dont know if you can stick a pin in the nozzle and adjust it that way?
Ron
N9QGS is offline   Reply With Quote
Old 01-11-2009, 04:38 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I have the same problem,the fluid seems to hit the base of the window and i just get a mist on the rest of the window,when i remember to do it i'm definitely going to use a pin to re-aim those nozzles.
Old 01-11-2009, 09:12 AM   #3
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
07 has a TSB on replacement washer cowl and/or washer nozzles. the cowl has a different angle point for the squirter....
Old 01-11-2009, 12:01 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Huh, when im at speed 50-60mph, my spray goes almost up and over, hitting the top and misting the rest, so if these can be adjusted that would be great.
not sure what that means.
Old 01-11-2009, 12:36 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
mine does the same thing, but also, the cold weather makes the fluid not flow as well. In the summer, it almost goes over the windshield.
Old 06-08-2010, 06:51 PM   #6
phaznet
phaznet's Avatar
Drives: '07 Yaris Sdn
The washer fluid seems to spray the wiper blades more than the windshield!
phaznet is offline   Reply With Quote
Old 06-08-2010, 08:50 PM   #7
severous01
there's a tool that you can stick in there. itls a screwdriver handle with a little tit on the end you actually insert into the jet and move around.
if you're careful you can use a pick. at least it's that way on mercedes, bmw and chevy and kia.
Old 06-08-2010, 10:10 PM   #8
Here's one of Crashy's 08 ones. They are definitely not the adjustable type. That would make sense with the TSB for replacing the 07's instead of adjusting them.
DIY- rattle from lower windshield fix. PetersRedYaris DIY / Maintenance / Service 3 08-21-2011 12:29 AM
Windshield Treatment Problem Yaris Newbie Wash, Wax, Detailing, Exterior Repairs 20 12-12-2008 01:43 AM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
chip in windshield deebrown General Yaris / Vitz Discussion 0 04-04-2007 12:58 AM
Windshield washer tank litres ??? lappie DIY / Maintenance / Service 2 03-20-2006 05:54 PM
