12-30-2013, 08:05 AM | #19 |
Drives: Toyota 86 GTS Join Date: Dec 2013
wow
Hi CTscot
I really like your post. Could you help me do the same thing but with a Toyota 86? Here is the wiring diagram http://www.ft86club.com/files/BRZwiringi.pdf I had a look at the Yaris diagram and it is similar but would really like some help. Thank you! |
12-30-2013, 08:44 AM | #20 | |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
You could try grounding the white wire in pin 20 of the headlight switch. If that works for making the headlights come on with the car off, then you would connect one contact terminal (30) of the relay to that wire and the other (87) to ground. You would then connect pin 17 of body ECU connector D5 to the relay coil terminal 85 and terminal 86 of the relay coil to the dome light positive wire (it doesn't look like there is a simple connector for grabbing that wire, so you would have to find one of the orange or light green wires on page 184/185.)
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Car doors are not self-locking when left unlocked | fainty_girl | General Yaris / Vitz Discussion | 27 | 03-14-2011 09:12 AM |
