Old 01-03-2014, 04:45 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Unhappy Mirror wiggle
Hi all and happy new year,
I've got a bit of an issue with my mirrors. They wiggle back and forth a little bit.
This a bit annoying when driving at certain speeds, with the wind they move back and forth quite a bit.
Any suggestions as to how I can stop this ?
I've put a video that shows the what happens:
http://youtu.be/YDpK9kZHwoc
Thanks.
JudgeM is offline   Reply With Quote
Old 01-03-2014, 09:01 AM   #2
It looks like the pivot bolt is loose. Are they power folding or normal ones?
Old 01-03-2014, 05:05 PM   #3
JudgeM
JudgeM's Avatar
They are power folding ones. The power folding works and even in closed position there is the wiggle.
Old 01-03-2014, 06:08 PM   #4
It may just be the backlash of the plastic gear train.
Old 01-04-2014, 12:53 AM   #5
JudgeM
JudgeM's Avatar
Arrow Problem found
I found the problem.
I took off the mirror and remove the screws that attach it to the wing.
Inside there are another set of screws that attach it to a bracket. I found that these screws are not fully tight and they are allowing some movement. This movement is quite small but over the length of the mirror it is amplified.
Refer to the picture and video.
http://youtu.be/jXKbegLiryU
I tried to tighten these screws but they seem at their limit already. I feel that if I add a washer to each screw it should do the trick ?
On a side note, should I add more threadlock when I put these screws back?
Old 01-05-2014, 09:32 PM   #6
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Light thread lock.....yes.
frog13 is offline   Reply With Quote
