Old 12-03-2011, 10:42 AM   #1
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
Sway bar noise?
Hey guys, i've recently installed the Ultra racing 23mm sway bar on my Yaris, and it works great!
But ever since i've put it on, i've noticed a thumping noise whenever I drive over a bump in the road.
I want to say it sounds like the shock absorbers, but i've never noticed them making this much noise before.
I have no other suspension mods, i'm on stock wheels and tires, and i'm only at 20k miles.
I'm not too worried about it as the car doesn't feel like anything is wrong, I just wonder what it is and if I should be worried about it.
Black_griffin6 is offline   Reply With Quote
Old 12-03-2011, 11:18 AM   #2
Noises should be explained, in my opinion. I would get under there and look for worn/bare/shiny spots where any contact might show.
Blue painter's tape or chalk can also be used to "mark" suspect areas.
Can you post a picture of the installed bar?
Are the bolts torqued down properly for sure? Re-torqued?
Old 12-03-2011, 12:06 PM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
takes some pictures of how you bolted it up on both sides and post 'em here
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-03-2011, 12:51 PM   #4
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
as garm says it sounds like rubbing between the bar and maybe the bottom of the shock? Perhaps on of the bolts has come loose and there's play which sounds like a thump in the cabin.
Old 12-03-2011, 03:30 PM   #5
Black_griffin6
Yeah, I think this is it.
I was going to check if the bolts were loose anyway, as i've read that you need to tighten them after you've driven the car for a little while after it's installed.
The ones on the shocks were a little loose, I got them tightened up so i'm going to try and go for a drive this evening and see if that has solved it.
Thanks for your help guys!
Old 12-03-2011, 03:44 PM   #6
A-Dingo-Ate-My-Baby
Drives: yaris
I found that... once tight, the 4 bolts on the UR23mm do not tend to work themselves loose after many miles of driving. over 15,000 on it and not once have they loosened
Old 12-03-2011, 03:53 PM   #7
Here is my DIY, shows the correct orientation of the bar:
http://www.yarisworld.com/forums/sho...t=diy+sway+bar
Old 12-05-2011, 11:20 PM   #8
Black_griffin6
Just an update guys: I tightened the bolts and that fixed it! All is well now. :)
Thanks guys!
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Sway bar link replacement salmonz DIY / Maintenance / Service 8 12-09-2010 09:30 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
