Old 04-26-2013, 07:30 PM   #19
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by lamadoo View Post
At what km did you change yours or would recommend?
I had mine changed at about 55k miles, or about 88514km. Really though, keep it until it is obvious it is hurting gas mileage, my gas mileage dropped 5 mpg, for no reason. Changed the transmission fluid, it went back to normal.
Explain please.
Dirty transmission fluid will negatively effect gas mileage. Even doing the drain and fill by hand a little bit every year or so is better than leaving dirty transmission fluid in there.
Colin Chapman disciple
Old 04-26-2013, 08:57 PM   #20
bronsin
bronsin's Avatar
Im going with driving 45 mph or less all the time and treating the gas pedal like its an egg will keep the transmission oil clean and sweet smelling.
Old 04-26-2013, 08:57 PM   #21
bronsin
bronsin's Avatar
Originally Posted by nookandcrannycar View Post
With the number of miles you drive, your Yaris will probably last you the rest of your life .
1034 miles October to March!
Old 04-29-2013, 03:37 AM   #22
Lance16
PlayToWin
Drives: 2008 Toyota Yaris Sedan
Thanks for the responses. I'm wondering is there anything special about an automatic versus a manual that makes the fluid change less necessary?
Lance16 is offline   Reply With Quote
Old 04-29-2013, 05:48 AM   #23
bronsin
bronsin's Avatar
Theres like two quarts of oil in a Yaris manual transmission and three times that in the automatic.
Old 05-23-2013, 12:16 AM   #24
Everglade
Crazy Russian
Everglade's Avatar
Drives: 2007 Yaris RS
Going to drain and fill ATF on my 2007 Yaris with 106k kms on it.
Will fill with Mobil synthetic ATF.
Update:
Desided not to ))
Ordered 6 jugs of Eneos... much better than Mobil.
Lower Viscosity = 5.7
Everglade is offline   Reply With Quote
Old 02-12-2016, 09:37 PM   #25
Pern
Drives: Yaris LE 2014
Go purchase Toyota WS fluid plus one more court than your car will hold.
1. Drain the pan.
2. Refill the pan with exactly the same amount you drained.
3. Locate and remove the fluid return line from cooler to transmission.
3. Remove it and drain into graduated container.
4. Start the car, drain out the balance of the fluid as you add the new fluid.
5. Reconnect the return line, top off the fluid to proper level.
(As an added benifit you can also change the filter if the fluid is really dirty and burnt).
This will get most of the fluid out of the car cost effectively.
Pern is offline   Reply With Quote
Old 02-12-2016, 10:27 PM   #26
CoryM
Drives: 2009 5-door, 5-speed
Automatics have "wet-clutches" meaning that the clutches are inside the case, and in the fluid. As the clutches wear, the grit ends up suspended in the oil, and in the filter if bad enough. They also create heat, which breaks down oil. Modern automatics are much better than older ones, but still do both of these things.
Old 02-16-2017, 05:55 PM   #27
dkwilfert
Drives: 2008 Yaris 2-Door (White)
Did a drain/fill on my wife's 08 Yaris a few weeks ago at about 52,000 easy miles, and the fluid came out brown; no burnt oder, just discolored. Because of this, I decided to do another drain/fill and to change the filter at the same time. On that drain, the fluid was red, but not clear, so the second change will help some more. I'm used to Hondas where I have always changed (drain/fill) the ATF at 25K-30K intervals, and it always comes out clear red. Even though Toyota says the fluid is supposed to last the life of the car, I would recommend the same 25K-30K drain/fill maintenance for the Yaris too.
dkwilfert is offline   Reply With Quote
Old 06-30-2017, 12:48 PM   #28
texascolt45
Drives: 2015 yaris
my 2015 has a drain plug and removable pan.wonder if the converter has a drain like some do?
texascolt45 is offline   Reply With Quote
Old 06-30-2017, 01:09 PM   #29
Rigaud
Drives: 2009 Yaris
no
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 07-05-2017, 09:26 PM   #30
Alain93
Drives: Yaris 12
If you drain and refill with the same amount, do that 3 or 4 times (once a week), after 4 times you will have change about 95% of the oil.
Alain93 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
transmission fluid that indicate must change susucosp DIY / Maintenance / Service 3 12-10-2011 11:51 PM
Carbon Buildup = Fuel Injection Flush??? zfarsh DIY / Maintenance / Service 24 10-30-2011 03:55 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
