Old 10-19-2015, 12:08 PM   #1
docppo
Drives: 2008 Yaris Hatchback
Vent knob cable
I've read all of the threads pertaining to the vent knob/switch, a/c switch, defroster switch, etc..., and have found that the reason the knob was not working was due to the thin cable popping out of the plastic circular assembly. I put the cable back in place, but when I turn the know the rectangular metal block connecting the wires on the inside of the circular assembly is sliding towards the inside of the switch which gives too much slack on the cable, which subsequently comes out again.
Does anyone have a picture of the knob/switch showing the complete assembly? I'm wondering if there's a clip that should be holding that rectangular block in place (as it does have grooves along the bottom 1/2. Thanks in advance!
docppo is offline   Reply With Quote
Old 10-19-2015, 06:38 PM   #2
Old 10-19-2015, 07:26 PM   #3
docppo
Thank you very much! I can see exactly what I'm missing!
Old 07-13-2016, 06:06 AM   #4
PMF3641
Drives: 2008 yaris sedan
same thing happened with my car with the vent control knob. but i can't seem to get that rectangular block part to stay in that slot it's supposed to be in. Am I supposed to disassemble the knob?
PMF3641 is offline   Reply With Quote
Old 10-21-2016, 09:45 AM   #5
Cigar_Maverick
Cigar_Maverick's Avatar
Drives: 2007 Yaris Hatchback
Howdy all!
Ever since I've had my 2007 Yaris Hatchback, the vent control knob has been "sticky." Difficult to turn. Until yesterday, I've been able to "work it loose." Last night, leaving work, it finally came undone. As usual, I was able to find the answer on how to fix it here. After I took mine apart, I noticed I had a bit more of an extensive issue. Apparently the cable cover broke off in the "holder" and the cable is now free. See picture.
You can see some of the brown cable cover still in the clip. Now the cable loop can pretty much come out of the control at will.
I need to know 2 things:
  1. What is the PN of this cable?
  2. Is there a post on this forum that details replacing this cable? I looked for a bit in the service manual last night and didn't see what I was looking for.
Any help is greatly appreciated.
Russ
Cigar_Maverick is offline   Reply With Quote
Old 10-23-2016, 01:34 PM   #6
Cigar_Maverick
Was wondering if 5590952120 was the right part number for this cable? Mine is a 2007 Yaris Hatchback.
Also, in the service manual, is there a section that describes how to take the old one out and install the new one?
Thanks,
Russ
Old 10-23-2016, 08:16 PM   #7
CB900F2
Drives: 08 Sedan
Hi Cigar..
I have the same issue with my 2008 Sedan.. the issue is , trying to disconnect the other end of the unit from the HVAC housing.. its a very very tight fit for my case.. Not sure if the hatchback uses the same HVAC housing.. you might want to check on this first..
Thanks,
Russ
CB900F2 is online now   Reply With Quote
Old 10-27-2016, 09:32 AM   #8
Cigar_Maverick
I ordered the part. Was $36 to my house. As long as I don't have to remove the dash... I can remove radio, glove compartment etc. I'll report back!
Old 10-27-2016, 12:01 PM   #9
dogsridewith
Drives: 2007 2-door hatchback
Rotary knob HVAC panel vent control
Sucks to hear this. Small 4-slider HVAC control panels of my high miles outdoor living winter suffering circa 1990 Tercel and Corolla were/are smooth and service free.
Old 10-27-2016, 05:15 PM   #10
Cigar_Maverick
Gives me purpose... Fixing my rubbish!
Any chance to be in the shop with a cold one and a cigar!
Old 12-24-2016, 12:25 PM   #11
Cigar_Maverick
Update:
FINALLY got started on this yesterday. This is where I ended up when I realized, much to my chagrin, that I accidentally ordered the wrong part.
I MEANT to have ordered a 55906A. What I THINK I did was order a 55909A.
The two pictures below show either end of the cables. On both, the one on the right side is the one that I just removed from the car.
Thus far, this has proven to be a project that SHOULD have been much easier. Not sure how any engineer thought this was acceptable.
More as I have it.
Old 12-24-2016, 02:48 PM   #12
CB900F2
Drives: 08 Sedan
DAM!! how tight was the space on the HVAC side??.. would you be able to post some pics on the HVAC side you remove the dial from?
Old 12-25-2016, 01:02 PM   #13
Cigar_Maverick
I'll be happy to post pictures as soon as I get the right parts!
Old 04-11-2017, 05:43 PM   #14
essarr
Drives: 2006 yaris
Did you end up taking pics ?
I need to replace mine because the cable is actually broken now
essarr is offline   Reply With Quote
Old 01-09-2021, 05:11 PM   #15
ehud42
Drives: 2009 Yaris Sedan 5spd
Late to the party, but I'm on my 2nd farmer hack/fix to this similar problem. '09 Yaris Sedan. Selecting the windshield in cold weather is hard. So hard the strain blew the cables out like yours.
Last time I was able to shim the sheath back into the control and hold it in place with a bit of tin, crazy glue and a zip tie. That lasted a few years. And this week it sprung open again.
I'm not tearing my dash apart in an unheated garage in January in Winnipeg. Not even if we are above normal temperatures. :-)
After some contemplation, I'm trying magic wrap. After getting the control line re-wrapped back on the dial, I took some pictures. I had contemplated trying to just shorten the control lines - but while debating how to secure them together like that little brass thing does, I thought about just trying to wrap it all.
So I cut the tabs off that hold something I've never had/seen (ie: they're useless at this point), and then wrapped in magic wrap.
Here's hoping it holds at least another couple winters.
https://www.flickr.com/photos/flying...7717813058992/
[IMG]IMG_20210109_153003_343 by Alex Wiebe, on Flickr[/IMG]
[IMG]IMG_20210109_154416_326 by Alex Wiebe, on Flickr[/IMG]
ehud42 is offline   Reply With Quote
Micro Image Short Shift Kit DIY jpmck03 DIY / Maintenance / Service 17 02-24-2014 07:57 AM
Steps to install a subwoofer in Yaris 2008 HB eepp In Car Entertainment + Electronics (audio / video / alarm) 2 11-20-2013 07:30 PM
Classic shift knob from TWM Performance now available with engraved shift patterns! TWM Performance TWM Performance 0 07-21-2009 10:57 AM
Feb Shift Knob Sale From TWM! TWM Performance Sponsors Classifieds Area 2 02-18-2007 10:15 PM
Newest Shift Knob From TWM! TWM Performance Sponsors Classifieds Area 0 01-10-2007 01:47 PM
