04-22-2018, 02:48 PM | #1 |
Drives: 2015 yaris hatchback Join Date: Jan 2018
spoiler install
my 2015 4dr LE Hatchback didnt come with a spoiler. if i get a toyota oem spoiler, is drilling required for installation?
04-22-2018, 03:01 PM | #2 |
Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
The one you have pictured can be held on with 3M tape only.
04-22-2018, 11:30 PM | #3 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
it can, but if you look at the little covers underneath; there are brackets in there that can be installed by drilling a hole and using included plastic inserts. (i used metal threaded inserts and a bolt) also, i believe there are 2 plastic arrow clips on the spoiler that will have to be removed if you don't drill alignment holes. (if installed from factory)
04-23-2018, 12:01 AM | #4 |
Drives: 2016 SE Join Date: Nov 2015
heres what mine looks like with the hatch up
probably doesnt help much |
04-23-2018, 10:38 AM | #5 |
04-23-2018, 10:40 AM | #6 | |
04-23-2018, 10:53 AM | #7 |
Factory installed would be drilled. I'm saying, for that particular spoiler, 3M tape would do the job. It's a scary thing to take a drill to your body panels.
04-23-2018, 06:39 PM | #8 |
im just a little lost because the spoiler in the pic is a factory toyota oem part.
04-23-2018, 08:31 PM | #9 |
you don't have to. the covers clip into place. they install the bracket for safety, but the drilling is easy;
-hand tighten nuts on bracket, spoiler side -hold spoiler in place where it is live forever -mark holes with marker -remove spoiler and drill holes -put tape on the drill bit at 5mm if you are scared of drilling too deep. -use touch up paint around bare metal it's super easy to do, but if you use just the tape, make sure to use some really good stuff, like VHB 3m |
05-26-2018, 07:26 PM | #10 |
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
i just got the spoiler off the internet with no guides and a broken LH cover XD how do i install this is there one way it fits on?
Similar Threads | ||||
DIY Sedan Spoiler Install | Kaotic Lazagna | DIY / Maintenance / Service | 36 | 01-19-2020 11:35 PM |
Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
DIY Hatchback Spoiler Install | skootdog | Cosmetic Modifications (Exterior/Interior) | 29 | 06-14-2016 04:44 PM |
What would the labor costs be to install a spoiler? | JerseyJeff84 | Cosmetic Modifications (Exterior/Interior) | 11 | 08-22-2010 07:24 PM |
DIY Sedan Spoiler Install Interest? | Kaotic Lazagna | DIY / Maintenance / Service | 28 | 09-11-2007 11:02 PM |
