10-06-2015, 04:28 AM | #1 |
Drives: yaris sedan 2007 Join Date: Oct 2015
need help in swaping my yaris engine
hi all
i have yaris sedan 2007 with 1.3 vvti 1nz-fe engine... i made many searches to swap my engine ... the easy one is 1.8 2ZR-FE it is already in yaris RS. there is other engine better 2ZR-FAE in corolla with better horse power and fuel consumption don't know it can fit or no.. my other opinion is 2zz-GE engine gives 180 to 190 hp .. but what i have to change in body or cut .. or it fits without cutting.. i prefer 1- 2ZZ-GE 180 hp 2- 2ZR-FAE 142 hp 3- 2ZR-FE 130 hp the easy and availabe is 2ZR-FE .. with complete wire and ecu don't know should i buy with it transmission gearbox both have 5 manual .. also should i have to change the fuel pump and radiatior or no ? lat question is 2 ZR-FE wiring should fit speed and rpm ... and should i change the whole exhaust system Last edited by maverickhere; 10-06-2015 at 04:38 PM. |
10-07-2015, 05:35 PM | #2 |
2ZR swap. DO IT! Ask how!
There are a few threads about swapping the 2ZR-FE already on the forums. It's a bolt-in solution if you get the whole motor from a Scion xD. 2ZZ = lots of fabrication and wiring. 2ZR-FAE = unknown fabrication, unknown wiring.
10-25-2015, 01:50 PM | #3 |
Drives: 2009 Yaris Join Date: Jan 2014
2zz-GE has been done with the 6-speed. Mechanical, somecutting mostly to fit the transmission.
Issue is the wiring and you better be good at it or know someone. I found some 2ZZ with 6-speed and ECU for $2000 - $2500 |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Toyota's new subcompact will use Mazda's Skyactiv engine | Kal-El | Off-topic / Other Cars / Everything else Discussions | 43 | 03-25-2014 01:01 AM |
Engine Cooling System LED in Yaris | lijet | DIY / Maintenance / Service | 7 | 09-09-2013 10:40 AM |
Engine goodies for the Yaris | botchilah | Performance Modifications | 8 | 01-28-2009 09:52 PM |
