Old 04-23-2014, 08:02 PM   #1
WeiseGuy
Drives: 2010 Toyota Yaris 4D Hatchback
Another Loss of MPG Thread...
Hey there guys,
Been awhile since I posted. I got my 2010 Toyota Yaris 5 door at the tail end of November 2013. I was getting (If I remember correctly) anywhere from 28 to 30 MPG. I just did my mileage the last 2 fillups and was SHOCKED (and a bit upset) that I'm only getting 24-25 MPG now. My oil changes have been caught up, and I just hit 91k so I'm getting ready for the 90k service, but is this normal? Would it be the 90k service that may be dropping my MPG? In 5 months of ownership, it has dropped from the 28-30 I loved, to 24-25 on average and I haven't changed my driving habits at all.
WeiseGuy is offline   Reply With Quote
Old 04-23-2014, 09:37 PM   #2
rustyspanner
Drives: 2010 Yaris YR 5 door
A bad o2 sensor will make it run rich and kill fuel economy - one went in my last car, and fuel usage went up by 30 percent. Even though it *should* throw a CEL, I'd get the mechanics to look in to it anyway. Otherwise maybe friction on the drivetrain somewhere, stuck brake etc?
rustyspanner is offline   Reply With Quote
Old 04-23-2014, 09:41 PM   #3
Killchain
Killchain's Avatar
Drives: '10 Yaris LB Polar White
Yes, a 90k tune up can and will help. Yet, not that youre a bad driver but just check if you are making easy mistakes.No jack rabbit starts, shift (manual Trans) at 2500 rpm.If you have a auto trans, change the fluid. Keep your speed down. Don't carry "junk" in the car. Trust me look at my signature gas mileage.
Killchain is offline   Reply With Quote
Old 04-23-2014, 09:44 PM   #4
WeiseGuy
I am SO jealous of that MPG in your sig Killchain...
It is an automatic so I'll be changing the fluid when I do this 90k maintenance in the next week or two. I feel that I don't do the jack rabbit starts and such, but will definitely look into it.
No CEL, but I'll check into the O2 Sensor as well. Thank you!
Old 04-24-2014, 08:08 AM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
90k. do check the spark plugs if they were not changed yet.
Old 04-24-2014, 09:38 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I'm kinda in the same situation with my Echo now. I thought it was mine worn set of standard plugs so put in a new set of NGK iridium plugs and although the engine runs smoother, I did not gain any MPGs. I did a long trip to Florida and back and was getting horrendous millage for all freeway driving. I think my average going there was around 32MPG US. When I got there I noticed the clean stainless exhaust tips on my Borla axle back were as black as could be. So the engine is running pig rich.
I'm thinking my O2 sensor is on it's way out as even as I got into the warm weather in lower states it was still using as much gas as in the freezing temps all winter.
Old 04-24-2014, 11:36 AM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Transmission fluid makes a big deal. So does having a super light touch when accelerating. Air pressure of the tires can hurt too.
Are you at sea level or in the mountains?
Colin Chapman disciple
Old 04-25-2014, 02:33 PM   #8
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
I can agree with why?'s suggestion about tire pressure. I run mine with around 37 PSI. My Yaris has not reached your total mileage as yet, but I know I have seen an increase in fuel economy with higher tire inflation. It can be something to consider.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Can't seem to break the 60 mpg barrier Amdkt7 Fuel Economy Forum 31 10-29-2013 06:46 AM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 08:38 PM
One Full Year of MPG Calculations YarisOwnersDad Fuel Economy Forum 36 01-14-2011 07:06 PM
FE Turnaround: Disappointment to Satisfaction, 2010 Yaris. Almost +50 MPH. Thank You! STC Fuel Economy Forum 12 04-16-2010 11:21 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 11:49 AM
