Old 11-15-2017, 07:46 PM   #19
SirDigby
Drives: 2007 yaris 3 door
yeah. did you swap the electronics of the throttle bodies?
did you pull the codes from the ECU?
Old 03-05-2018, 08:08 AM   #20
Dliverance
Drives: 2012 Black sand pearl <3
Is the spacer mandatory for this swap? I have an mr2 spyder here and I’m wondering if I should just go ahead and take the sensor and TB
Dliverance is offline   Reply With Quote
Old 03-05-2018, 10:03 PM   #21
SirDigby
^^^no. but it makes installing the throttle body where it can be removed easier more convenient...
Old 04-05-2020, 07:09 PM   #22
ravipasupuleti
Drives: 2013 Yaris LE
Hello, Thank you for putting together these details. i was able to swap my TB with your valuable info. I need help with the size of the coolant hoses, I ordered couple on amazon but none of them are the right size. for now, i bypassed the coolant lines. can you please share any link where you got them or the size. appreciate your help.
ravipasupuleti is offline   Reply With Quote
Old 09-16-2020, 10:30 AM   #23
jhsedward
Newbie
Drives: vios ncp42
Bro how im 1nzfe engine (1st gen vios ) also but without piggyback
And TB (cable )
How to upgrade it to 1zz TB
Since the Manifold just only 55 mm and the TB 70mm
jhsedward is offline   Reply With Quote
Old 04-17-2022, 10:05 AM   #24
corradovr6
Drives: yaris 2002 t sport
And TB (cable )
I'd be interested in this too - mine is also a 1nz-fe 1.5 t sport (UK). I think the tb mount is only three bolts
corradovr6 is offline   Reply With Quote
Old 10-30-2022, 07:57 AM   #25
Compeer
Drives: NCP90 TRD Yaris Manual
I think this is my next mod, these throttle bodies are cheap over here in NZ.
has anyone mounted the 1zz airbox too so the intake size matches? does it/would it fit?
Compeer is offline   Reply With Quote
Old 10-30-2022, 08:43 PM   #26
remcafee
you would probably scare the mass airflow sensor with the corolla intake
Old 10-31-2022, 12:23 PM   #27
Compeer
Fair enough, I also read you can remove the throttle lag with a celica pedal swap? You read about this before?
Old 10-31-2022, 10:13 PM   #28
remcafee
i did not see that post ill look for it, i dont see how a pedal would help with throttle lag, but i ended up taking the oem celica pedal pad and epoxied and screwed it on the oem yaris pedal
Old 11-01-2022, 12:51 AM   #29
Compeer
I will research this more and if i can find one I will try it for science.
Old 11-02-2022, 03:25 PM   #30
remcafee
https://www.yarisworld.com/forums/sh...ad.php?t=27172, i know of this one i was looking to solve my heel toe issue and came across this thread but i did not screw around with the lexus pedal i just took the aluminum pad and shaved it down flat on the back side and then epoxied and screwed it into the stock yaris pedal, it works very well and is sturdy and not going anywhere. i highly recommend getting a oem celica gts pedal and trying it, also get a spare gas pedal from a junkyard so if you screw up you dont fuck up your good gas pedal
Old 11-04-2022, 09:05 PM   #31
Compeer
Yeah smart, will do. Im pretty sure I seen in on 4wd upgrades for hiluxs with the same "laggy throttle" and them swapping them for celica ones which they said had a more "sporty throttle map". I can't find the video now tho for the life of me tho.
1zz or 2zz throttle body swap BoostedTRD Performance Modifications 1 11-25-2014 10:05 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 08:02 AM
Throttle Body Swap Ryze268 Performance Modifications 12 04-27-2014 01:46 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
