Old 03-18-2018, 02:17 AM   #1
m.flores.0928
m.flores.0928's Avatar
Drives: 2014 Yaris
Customized gauges
Before anyone asks, no, I didn't swap out my gauges for an SE style with a tacho. I'll do that eventually!
However, I decorated mine. Check it out in the pictures! It was so easy!
m.flores.0928 is offline   Reply With Quote
Old 03-18-2018, 06:28 AM   #2
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
Is there any logical reason for the totally unnecessary "F Bomb"?
mrpj is offline   Reply With Quote
Old 03-18-2018, 11:55 AM   #3
m.flores.0928
Drives: 2014 Yaris
Am I not allowed to be excited and proud of my work...?
Old 03-19-2018, 06:28 AM   #4
mrpj
Yes, but excitement surely doesn't entiltle the use of foul language on a public forum does it?
And has to be against the forum rules - "By agreeing to these rules, you warrant that you will not post any messages that are obscene, vulgar, sexually-oriented, hateful, threatening, or otherwise violative of any laws."
Old 03-19-2018, 10:16 AM   #5
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Looks like a clean job!
On Instagram
On Wheelwell
Old 03-19-2018, 07:13 PM   #6
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
Came out pretty sweet! I'd be staring at them instead of the road the whole time lol
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 03-20-2018, 02:35 PM   #7
some_0ne
Drives: Yaris
Customized gauges
Coul you tell about how you removed the assembly from dashboard. I need to clean some blur behind the glass.
some_0ne is offline   Reply With Quote
Old 03-20-2018, 03:30 PM   #8
jpmck03
jpmck03's Avatar
Drives: 2018 Volkswagen GTI
Old 03-23-2018, 01:40 PM   #9
m.flores.0928
Drives: 2014 Yaris
I'll get some more pics for you! Sorry for the delayed responses, I've been crazy busy
Old 03-23-2018, 01:41 PM   #10
m.flores.0928
Drives: 2014 Yaris
Originally Posted by jpmck03 View Post
This is the best response
Old 03-23-2018, 01:42 PM   #11
m.flores.0928
Drives: 2014 Yaris
Thanks! It took a few hours, I was trying to be super careful. The spray glue I used is pretty heavy duty so once it's applied, it's not coming off haha
Old 03-23-2018, 01:43 PM   #12
m.flores.0928
Drives: 2014 Yaris
I definitely catch myself getting a bit distracted sometimes! I might do this again as soon as I get my hands on an SE style gauge cluster with a tacho.
Old 03-23-2018, 03:28 PM   #13
m.flores.0928
Drives: 2014 Yaris
Here are some pics.
1: pop off the outer trim piece with some sort of pry tool like a flat head screw driver.
2: unscrew the two bottom screws with a phillips head.
3: pop out the top portion gently. It's held in the some clips.
4: fish out the entire piece from between the dash and steering wheel.
5: the clear plastic piece is clipped in with 6 clips. The clips are clear plastic.
6: you can separate the main body portion too, just pop out out the bigger black plastic tabs.
7: when you disconnect the harness, you'll have to reset the clock. No big deal. However, I recommend keeping all gauge needles at bottom resting position when you reassemble it because I suspect them being offset if you reassemble it with the needles off resting position.
Old 03-23-2018, 03:57 PM   #14
some_0ne
Drives: Yaris
Here are some pics.
4: fish out ...
Thanks for your effort. It is more complicated than I thought. I do not know if I can dare.
Old 03-23-2018, 03:58 PM   #15
m.flores.0928
Drives: 2014 Yaris
It's way easier than you might think. I can get it disassembled to its individual parts in like 10 minutes without being very careful, honestly. It's made of plastic but it's pretty tough plastic. I'm not beating on it but I'm also not babying it. It's pretty easy!
Old 03-23-2018, 03:59 PM   #16
m.flores.0928
Drives: 2014 Yaris
Also, I believe toyota sells just the clear plastic piece by itself. I think it has its own part number
Old 03-23-2018, 04:19 PM   #17
some_0ne
Drives: Yaris
Customized gauges
Let me ask first Toyota service station.
I was searching in all Toyota forums but could not find any info about dismantling this type of cluster. Thanks again...
Upper driver's side glove box w/ holes cut for gauges PETERPOOP Items for Sale by private party 9 07-31-2011 07:21 PM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
My new gauges set up PETERPOOP Cosmetic Modifications (Exterior/Interior) 30 04-19-2009 08:50 PM
Mechanical vs Electric Gauges? PETERPOOP Forced Induction Forum 13 04-06-2009 01:25 AM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
