Old 09-23-2006, 10:18 PM   #1
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Need Wiring Help
I just installed an electric spoiler sunroof - I just need power to it.
I need a circuit to the battery and one that goes on and off with the ignition. I routed the wires down under the driver's side dash. I'd like an OEM installation. How do I hook these into the fuse panel? They should have their own circuit.
Thanks.
Old 09-24-2006, 10:54 AM   #2
Violin
Violin's Avatar
Old 09-24-2006, 04:12 PM   #3
Violin
Violin's Avatar
Well... I used two of these add-a-fuse suckers and put them in unused spots in the fuse block The only trouble is now I can't put the cover back on. It works for now.
Old 09-24-2006, 04:13 PM   #4
Violin
Violin's Avatar
Advice would be appreciated.
Old 09-24-2006, 04:51 PM   #5
paultyler_82
Drives: 07 Meteorite Metallic Yaris LB
You're wanting to use the unused OEM panel spots without that adapter thing, correct?
paultyler_82 is offline   Reply With Quote
Old 09-24-2006, 06:57 PM   #6
Violin
Violin's Avatar
That's what I ended up doing but I'd rather wire directly into those unused panel spots so it all looks factory.
This works but I'm a perfectionist.
Old 09-25-2006, 06:45 AM   #7
paultyler_82
Hmmm, I'd have to take a look at the fuse panel, but if you can remove it from it's spot it should just be a matter of putting a female spade connector on your power wire, then attaching it via the backside of the panel on the opposite pin of the provided power pin... does that make sense? here, I'll draw a picture... hopefully this makes sense?
Old 09-25-2006, 07:01 AM   #8
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
Send a message via AIM to vodkalush
ummmmm.... I might just have to redo my power outlets so that they all have their own fuse (which is prob the way I should have done it :-) ) on the block.
If I do, I'll make sure to take a ton of pics and post a DIY.
Docotrs say all the drikning has mesesd up my seplilng and radieng
will work for parts
vodkalush is offline   Reply With Quote
Old 09-25-2006, 10:46 AM   #9
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
Of the Sunroof,That is
YamilR is offline   Reply With Quote
Old 09-25-2006, 12:44 PM   #10
Violin
Violin's Avatar
Thanks Paul. The fuse block is on the bottom of this:
(image stolen from H8SGAS's thread)
Let's just say I was a little intimidated about taking it apart.
YamilR - the photos are here: http://www.yarisworld.com/forums/sho...5&postcount=31
Old 09-26-2006, 04:15 AM   #11
paultyler_82
Not a problem, just glad I could help, I've done so much aftermarket stuff in my cars, but I always like to keep it OEM looking myself. Oh, and that sunroof looks great!
US Yaris: Adding a tach? Thirty-Nine General Yaris / Vitz Discussion 159 04-05-2007 08:23 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
question about stock stereo wiring? punch In Car Entertainment + Electronics (audio / video / alarm) 3 07-19-2006 03:22 PM
