05-06-2011, 07:31 PM | #1 |
Budget Buster
ATX temperature overheating?
New to this forum and looking for information.
I have enjoyed this forum over the past several weeks and have gained an incredible level of knowledge regarding my recently purchased 2007 Yaris sedan. Thanks to all of you for this great source of information. I recently blocked the lower grille for FE purposes. I have been watching the water temps closely using my Scangauge with a maximum temp thus far at 202 degrees F. Well below overheating... My question is in regard to the threat of an overheated ATX due to the blocking of the lower grille. Is there a threat of overheating the ATX with the lower grille blocked? I have been unable to locate the TFT code (transmission fluid temperature) on my Scangauge to watch this temp. Any Scangauge users out there who have been able to program the Xgauge to show TFT? If it were available, what would be considered an excessive temperature? Thanks for any info that can be provided. |
05-06-2011, 08:32 PM | #2 |
wow, fancy seeing you here. (same guy from gassavers)
I was going to say that you could unblock your lower grill and see what kind of temps you are getting normally and go from there. if nothing else, it will give you a good baseline. you said you had it on toggle bolts, that should be easy enough to remove and replace. maybe give it a week when you know it is going to be a hot one. ****edit**** dang it, misread your post. thought you had gotten 202 as trans temp. one thing you could do is try the code for the ford trans temp and see what happens. the worst that could happen is you get an erroneous reading. http://www.scangauge.com/support/pdfs/XGAUGE.pdf it is under enhanced data on page 4 or so. you could also give them a call. they are usually very helpful. |
05-07-2011, 02:47 AM | #3 |
Budget Buster
Hello again, BEEF!
Thought I'd give the ATX temp question a shot on this forum, but I wasn't expecting such a small world! I saw the Ford tranny codes on Scangauge. May give them a try. I have emailed the Scangauge support desk requesting additional help. Waiting to hear back from them as well. Hoping for some specific help from a Yaris "expert" on this forum. |
05-07-2011, 06:56 AM | #4 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
This is kind of an odd one. There is a temperature sensor for the AT that is a direct input to the ECM, and in the service manual "A/T Oil Temp" is listed as one of the data items for the AT, but when I connect my Toyota TechStream tool to the Yaris and go into the section for the AT, the only temperature parameter listed is coolant temp. And, if I sniff the communication stream with my CAN Bus sniffer, TechStream is just requesting the standard water temp PID.
05-07-2011, 08:00 AM | #5 |
Now, does the AT even have a cooling loop that runs through the rad, or is it purely air cooled?
05-07-2011, 08:47 AM | #6 |
It has a transmission fluid cooler.
05-07-2011, 08:54 AM | #7 |
Does it run through the coolant though? Or is it just a loop in front of the lower part of the rad. That makes a difference. If it's going through the rad the transmission temps should be pretty close to the coolant temps. If it's an open air loop in front of the lower part of the rad it won't be getting the airflow it requires.
05-07-2011, 09:24 AM | #8 | |
Similar Threads | ||||
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
2007 Toyota Yaris Temperature Question | bhola | General Yaris / Vitz Discussion | 17 | 06-25-2010 06:46 PM |
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
Temperature Guage install | bieniman | DIY / Maintenance / Service | 3 | 03-12-2009 02:45 PM |
Water temperature | Bob_VT | General Yaris / Vitz Discussion | 11 | 11-03-2008 03:17 PM |
