Old 02-27-2016, 07:07 PM   #1
SirDigby
Drives: 2007 yaris 3 door
Installed P&P manifold and 1zz TB
Finally installed 1zz TB and Ported manifold. (and throttle body spacer)
http://www.yarisworld.com/forums/pic...pictureid=6127
i had to modify the intake by cutting about 1/2 in off where it comes to the TB so it would seat properly.
here it is with the engine cover. you can't see the red in the picture, but it looks good when you can see it in the darkness of the shadow in real life.
http://www.yarisworld.com/forums/pic...pictureid=6128
i like the spacer! everyone always asks, "is that a block of wood?"
ha!
here is another angle:
http://www.yarisworld.com/forums/pic...pictureid=6129
Old 02-27-2016, 07:16 PM   #2
SirDigby
one thing i now understand about adjusting screws on 1zz throttle body.
the outside screw (the one that needs chipped away) is for adjusting COLD IDLE STOP!
i kept trying to adjust screw after warm up. it does not adjust anything after the engine has warmed up! it needs to be adjusted 30 seconds after start up, but not more than 2 minutes or so. (depending on outside temperatures)
to adjust warm idle, the screw for that is located INSIDE the TB. it took me a week to get this figured out.
if you adjust the screw too far out, it will go into limp mode! (cold idle screw) you will have to clear code and tighten screw a turn and try again. (i did not adjust warm idle screw on the inside)
I've got it running pretty good now. i noticed my gas millage increased 2.75mpg in the last week after installation.... ha!
Tags
1zz throttle body, cai, custom intake, ported manifold, throttle body spacer
Micro Image/Golden Eagle Intake Manifold Review tmontague Performance Modifications 18 01-03-2017 08:24 PM
FS: Ported (for 1zz) OEM intake manifold tmontague Items for Sale by private party 6 04-01-2016 11:25 PM
JB Weld stock intake manifold port w/ 1ZZ Throttle Body tmontague Performance Modifications 2 10-07-2015 09:31 PM
1zz intake manifold crazylegs Performance Modifications 7 08-02-2015 08:02 PM
manifold 1zz to 1NZ? Nets Performance Modifications 3 05-09-2010 12:22 PM
