Old 05-29-2014, 07:17 AM   #1
vincentg
vincentg's Avatar
Drives: Toyota Yaris 2007
Water on the floor of my yaris
Hi guys.
I have a 5 door hatch 2007 yaris. Upon cleaning the carpet, i found out that there is water - and lots of it - tried to clean it up but i want to know if there are known issues with our yaris regarding the leak.
JUST DRIVE
vincentg is offline   Reply With Quote
Old 05-29-2014, 07:58 AM   #2
There are rubber plugs through the floor in those areas. Take a look under the car to see if they are missing.
Old 05-29-2014, 08:00 AM   #3
nortonfb
Drives: 2007
I'm not familiar with the sedan.
However a few likely causes can be, sunroof seal, rubber plugs in floor pan
and window seals.
I found a leak in my HB it was caused by the plug in the trunk.
The edge was rolled. I heated with a hairdryer and put grease under the lip.
Steve
nortonfb is offline   Reply With Quote
Old 06-07-2014, 07:04 AM   #4
vincentg
vincentg's Avatar
I found the culprit. Its the AC drain! Thanks for your reply! :D
JUST DRIVE
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Testing water on 3 Drive Throttle Controller for Yaris (Vitz) twpanson Performance Modifications 57 10-31-2009 02:07 AM
