Old 02-28-2016, 04:41 PM   #1
Keymaster
Drives: Yaris '06 1300cc
Rear brake disks sliding bolt torque
Hello guys, I am searching for the correct torque that I need to apply when I will remove the sliding bolts from the rear brakes in my Yaris. The model is 2006 and the back axle has brake disks. It is rather challenging to find info for the removal of rear brake disks, because all the manuals that I've found so far, they have only drum brakes related info.
Thanks a lot!
Keymaster is offline   Reply With Quote
Old 02-28-2016, 05:36 PM   #2
Frank the Tank
Drives: 2007 Toyota Yaris
Your car came from the factory with rear disk brakes? That's pretty cool.
I would call the dealership and ask one of the technicians.
Frank the Tank is offline   Reply With Quote
Old 02-28-2016, 07:06 PM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I've noticed that the torque specs for front caliper bracket and pins for the Yaris are the same as the Corolla torque specs.
I would say go with the same specs as the Corolla rear disk breaks and you probably won't go wrong.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 02-28-2016, 07:50 PM   #4
Thanks a lot!
For the European Yaris with rear disc brakes, I am seeing:
39 N-m (400 kgf-cm, 29 ft-lbf) for the slide pin torque.
Old 03-01-2016, 03:09 AM   #5
Keymaster
Yes, it was from the factory
Thank you very much CTScott you saved my day, I have been searching for this info a couple of days in manuals and I was about to go for corolla specs.
Old 04-08-2016, 01:23 AM   #6
Keymaster
I return back with one more question regarding torque. The place is rear brakes with disks and the bolts is the one in the photo. Any input is very welcome :-)
Old 04-12-2016, 03:53 AM   #7
Keymaster
I finally found the info that I was looking for. Here are the torque for the rear disk brake in a 2SZ-FE:
Catback exhausts and rear disc brake conversions eTiMaGo Performance Modifications 59 01-04-2009 06:13 PM
Yaris/Echo Rear Brake Question pdarnell DIY / Maintenance / Service 2 08-21-2007 01:15 PM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-25-2007 11:10 PM
