10-06-2010, 12:49 AM | #1 |
Drives: new vitz Join Date: Apr 2010
SCrreeech
Hi dearest members, my greetings. I have a Yaris HB ,auto year 06. Since i have bought it , every morning i starts it, it screeches for 11sec and then it starts. I dont know where the problem is? Can anyone help me.........
10-06-2010, 01:01 AM | #2 |
Not quite a noob
Is it a grinding screech or a high pitched whirring screech
10-06-2010, 08:16 AM | #3 |
My guess for a screech would be the serpentine belt. Since it is an '06, this belt has either stretched and needs to be re-tensioned, or it has reached end of life and needs replacing.
10-06-2010, 09:33 AM | #4 |
Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Yeah, could be the belts being old and worn with moisture on them.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
10-06-2010, 09:41 AM | #5 |
Yep, I agree the its the belt. First check the belt if its worn or a bit torn change it but if its good then you can loosen the alternator a bit to tighten the belt, good luck buddy
10-13-2010, 11:30 AM | #6 |
wooow thnx for ur reply but when in the morning when am going to start the car for the first time, it does that grindd for 11 sec and then starts. Its an 06 car,auto.
so if someone can tell me where this belt is found or any image to show. it would be of great pleasure. |
10-13-2010, 11:33 AM | #7 |
or is it the timing belt?
10-13-2010, 05:02 PM | #8 |
Nah man its not the timing belt, just look for your alternator belt you only have one that is visible push down on it and you will notice that the belt is not tight and just loosen the alternator screw and tighten that baby up and that will resolve your problem
10-13-2010, 06:53 PM | #9 |
Drives: 2009 Yaris Onyx Join Date: Dec 2009
10-13-2010, 07:05 PM | #10 |
Not quite a noob
Our cars have timing chains, IIRC. At least, all the japanese made ones do.
10-13-2010, 07:13 PM | #11 |
reading over husaynkhan post it sounds more like a starting system problem.
10-13-2010, 07:48 PM | #12 |
toyota
its just the belt...try belt dressing,,or just replace it..but make sure you get someone to do the proper tension eitherwise its still gonna squeel even if its new..
10-13-2010, 11:30 PM | #13 |
Ain't that the truth, I hope he does the job instead of paying someone to do it its simple even a cave man can do it lol
10-14-2010, 09:35 AM | #14 | |
OP - please clarify when exactly you experience this noise. Also, you have described your issue as both a 'grind' and a 'screech'. Which is it? The belt will not cause a grinding sound.
10-17-2010, 08:21 AM | #15 |
ya DARK AGE 53 thas wat am telling
10-17-2010, 08:22 AM | #16 |
can anyone post a pic of this belt u alll are saying......
10-17-2010, 08:28 AM | #17 |
10-17-2010, 05:25 PM | #18 |
o.k, so it takes 11 sec for the engine to start and while it's cranking over it makes the screeching noise, now once the engine fires up does the noise goes away or does it continue making the screeching noise.......if the noise stops it's probably the starter and not the belt.
