Old 10-25-2015, 07:45 PM   #145
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by valchrist90731 View Post
If your grinding while shifting into reverse. Learn from your mistakes. Put the car into first gear then shift it in reverse. Grinding is due to the driver most of the time.
Have patience with your car and it will drive smoother.
This was to inform all on how to reduce grinding when shifting into reverse.
This was written respectfully as possible.
I will be as respectful as possible as well. This issue with shifting into reverse with the stock or other conventional fluod is a known issue. Expecting someone to shift into first just to shift into reverse is unacceptable. Telling someone to be patient isn't a cure to the problem. Sure, it is possible that drivers are over anxious to shift, but the issue has even been noted in published reviews. Once again reviewers could be over anxious to shift, but they have experienced many many manual transmissions in most cases so they have firm ground to stand on regarding the behavior. I have driven a few dozen different manuals from various vendors and have experienced this only on well worn transmissions not brand new ones. I had the issue within the first 1000 miles. Changed to synth and bam, resolved. There is a reason why so many manufacturers are switching to even requiring synthetic; it is a much more tolerant and better working lubricant.
Sent from my SCH-I545 using Tapatalk
Old 10-28-2015, 09:56 AM   #146
tmontague
tmontague's Avatar
Just sources some Redline MT-90 from a local store near me for $21 a quart, not too bad a price. I'll be picking it up later this week and putting it in this weekend.
I get a slight quick grind when shifting into reverse in the morning in my driveway and I'm currently running 75w90 synthetic. Not much better than oem just a little thinner in the dead of winter.
I'll leave my thoughts on here once I test it out.
Old 10-31-2015, 08:19 PM   #147
tomm9050
Drives: Yaris 2008 HB
GL-4 or GL-5 WHat's the difference. What's the verdict on what's best?
Thx
tomm9050 is offline   Reply With Quote
Old 11-01-2015, 08:58 AM   #148
tmontague
tmontague's Avatar
GL-4 seems to be what give much smoother shifting over GL-5. I've installed my GL-5 tranny fluid but haven't driven the car to try it out yet.
Old 11-03-2015, 03:27 PM   #149
tomm9050
What about Amsoil 75/90? It only comes in GL-5. Any suggestions?
http://www.amsoil.com/shop/by-produc...?code=SVGQT-EA
Old 02-10-2016, 12:36 PM   #150
strandrrs
Drives: 2009 Yaris 5-door Hatch
Can transmission fluid just be added at the dipstick entry for auto?
Hi -
I have a 2009 5-door hatchback Yaris.
Thanks for the great DIY instructions and photos - so helpful.
Can I just add the Toyota transmission fluid there? Do I have to drain it? If so, can I drain it from the bottom, the same way as the manual?
Thanks so much!
strandrrs is offline   Reply With Quote
Old 03-05-2016, 05:39 PM   #151
Aclosefriend
Drives: 2008 2dr Yaris Hatch
Thanks for this. I bought a 08 Hatchback a few months ago with a 5 speed MT with 65k miles. This was so easy and the shifting is much much smoother now. Only took 20 minutes, and most of it was waiting for the fluid to drain and for the fresh thick gear oil to flow down the tube.
Aclosefriend is offline   Reply With Quote
Old 01-29-2017, 09:40 AM   #152
Evansba2
Drives: Toyota yaris 2008 sedan manual
please is Redline synthetic oil, API GL-4 Gear oil
SAE 75W80 manual transmission oil good for Yaris.
Evansba2 is offline   Reply With Quote
Old 01-29-2017, 08:38 PM   #153
dogsridewith
Drives: 2007 2-door hatchback
Which oil did you go with?
Old 07-22-2018, 02:47 AM   #154
Rigo93shred
Drives: 2009 red 2 door hatch yaris
I just got a yaris 2 door hatch 5 speed with 105k miles and idk if the tranny oil has ever been changed it shifts nice never had a standard but i dont hear grinds or anything in mine the previous owner had it for 3 years and never mentioned trany oil change should i change it along with all fluids just to start fresh or would new oil mess up my tranny cuz its good i sort of cant stand not knowing if its clean or not and if its never been changed should damage happen to it???? Sorry for the long post 1st car and i wanna baby it good
Rigo93shred is offline   Reply With Quote
Old 09-07-2018, 08:33 AM   #155
timbstir
Drives: 2010 Yaris Seden
So I did my gear oil yesterday and I took the fill plug off first, and when I did oil started to pour out (less than a quart), did this happen to anyone else?
timbstir is offline   Reply With Quote
Old 09-07-2018, 09:03 AM   #156
tmontague
tmontague's Avatar
That is fine it just likely wasn't overfilled before due to the front end being jacked up higher than you had it.
FWIW I over fill my trans fluid by about half a quart
Old 09-07-2018, 10:02 AM   #157
IllusionX
Drives: 07 Yaris Sedan Aero
Not much came out when I did mine. Had a flat surface though.
Then poured 2qt in, small quantity came out and that's what I left it at.
Sent from my VTR-L09 using Tapatalk
Old 09-07-2018, 01:43 PM   #158
timbstir
Yeah it wasn't much that I had pour out, it was up on jack stands. The worst part was that I wasn't anticipating it so I didn't have a catch pan ready at the time so I had to spend the next half hour trying to clean my friend's garage. I put in about to quarts on level ground afterwards and it seems to be doing fine, it shifts way smoother than before.
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 01:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
